Computer question and FUEL INJECTION question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Computer question and FUEL INJECTION question
BlackMagicBrakes 7% Discount, Save today!Poison Spyder from CCOR!HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made I
Unread 10-10-2006, 07:36 PM   #1
MontyWilco
Im taking the 258Ci from an 1980 CJ-5 and dropping it into my YJ, i plan on putting fuel injection on it, my first question, sence i can take the head and manifold off a 4.0 can i take the fuel injection off it also? once my swap is done, what should i do for a computer? do i buy a aftermarket one specialy for the swap or do i use the CJ one? thanks for the help
MontyWilco is offline   Reply With Quote
Unread 10-10-2006, 08:40 PM   #2
86cj74.2L
86cj74.2L's Avatar
If your starting from scratch I would concider making a 4.5L out of a 4.0L block with the 4.2L crank, and which ever rods and pistons (I do not remember if you use the 4.0 or 4.2 rods and pistons.
Is your YJ a factory 6cyl or are you replacing a 4cyl engine?
86cj74.2L is online now   Reply With Quote
Unread 10-10-2006, 09:31 PM   #3
MontyWilco
its a 4 cyl. but i already have the 4.2L
Unread 10-10-2006, 11:24 PM   #4
Bill USN-1
If you have a complete donor vehicle with the MPFI, then take everything.
Wiring harness, computer, sensors.......
Swap everything in as a complete running motor.
If you are not referring to the MPFI then you should start with a search and possibly the sticky at the top of the forum.
Bill USN-1
[B]75 scout XLC 345/727/JPD300/3.73's/33's/4wdisc/hydroboost/EFI[/B] ><>< 76 scout 345/727/D300/354's/37's/EFI/SOA
FI Moderator at [URL="http://www.binderplanet.com"]Binder Planet[/URL]
Bill USN-1 is offline   Reply With Quote
Unread 10-11-2006, 09:21 PM   #5
MontyWilco
well i have a 4.2L, i want to take the head and manifold off a 4.0L to put on my 4.2L. i would like to put Fuel Injection on it also, can i take the 4.0L injection and put it on the 4.2L with the 4.0L head and manifold? sorry for the confusion i should have been more spacific. im looking to see what parts i should buy.
