Compression question on 258 - JeepForum.com
post #1 of 29 Old 02-26-2013, 08:52 PM Thread Starter
ironbyron1
1977 CJ5
I've been told by one mechanic my 258's compression tested at 150. Another shop told me today it is 70 in all 6 cylinders. 150 is spec. Would it even run at 70? And the shop that told me 70 said it is the rings not the valves. If the rings were that bad wouldn't it smoke like the dickens? It doesn't smoke one bit.
The reason for the test is trying to find why it is so hard to start, and misses so much. That aside, it is running better and more powerful than ever. I still wonder if it has jumped a tooth on the timing, or maybe the timing chain is worn. It won't harldy run at all if you set the timing properly. It has to be advanced a lot to run. Any advice please! Oh and it has new, carb, distr, control module, dstr cap, rotor button, plugs and wires, fuel pump, vacuum is fine, fuel filter is fine.
Byron Oost
Owensboro, Kentucky
ironbyron1 is offline
post #2 of 29 Old 02-26-2013, 09:19 PM
86cj74.2L
86cj74.2L's Avatar
Buy a tester and do it yourself. They are not expensive. Or rent from a autoparts store.
86cj74.2L is offline
post #3 of 29 Old 02-26-2013, 10:09 PM
cj5huntingrig
1974 CJ5
X2. I bet you have a leak at your intake manifold. Soak the intake with carb cleaner where it connects to the head while running (cold) and if it picks up speed or smooths out, you need to replace your gasket.
Also, to answer your question, the guy who told you 70 is probably lying.
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #4 of 29 Old 02-27-2013, 02:44 AM Thread Starter
ironbyron1
1977 CJ5
No intake leaks have been found either. They could be lying, but I think the guy who did the test just didn't know what he was doing. Either way I don't see how he can be right.
Thanks for your advice.
Byron Oost
Owensboro, Kentucky
post #5 of 29 Old 02-27-2013, 04:16 AM
86cj74.2L
86cj74.2L's Avatar
I am surprised how many think you just screw in the compression tester and crank away. It must be held wide open throttle during cranking with all spark plugs removed.
What carb are you using?
When was your last tune up?
post #6 of 29 Old 02-27-2013, 06:32 AM
BagusJeep
1981 CJ7
SOunds indeed that the carb was not held open.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 29 Old 02-27-2013, 06:34 AM Thread Starter
ironbyron1
1977 CJ5
All of the things that I listed as having been done are a work in progress to get it back up and running. It died on me one day and wouldn't run at all. From there all the things I listed have been done, starting with 3 control modules. The guy who put the first one one decided it should have a detachable pigtail on it so he wired one in. Well he wired it backwards and when it wouldn't run he blamed it on the carb. Turns out he hates carbs and will not touch one. The next guy who worked on it discovered that, guess what, the control module the first guy put in was burned up. So he put a new one in, only to have it promptly burn up since the pigtail was still wired backwards. So, he figured that out and now the engine is running again, but just barely. Keep in mind it was running fairly good before it died on me. Then all the other stuff listed above was added in an attempt to bring it back around.
The only thing that hasn't been checked is the timing chain, and the valves/pushrods have not been closely scrutinized. That was supposed to have been done yesterday, but when they found the compression to be 70 (I still think that has to be wrong) they went no further.
Thanks!
Byron Oost
Owensboro, Kentucky
post #8 of 29 Old 02-27-2013, 06:58 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It sounds like you still need to find a competent mechanic, or learn how to work on your CJ yourself.
I doubt an engine with 70 compression would even run. If it did, it would smoke like Cheech and Chong's van on a Saturday night. I can't believe your mechanic is trying to sell you that crap. Aren't there ANY honest wrench-monkeys any more?
Have you, or your mechanic even checked timing? I think your instincts are right on the money. Timing chains often stretch, and can skip a tooth.
Matt
Matt1981CJ7 is offline
post #9 of 29 Old 02-27-2013, 07:31 AM Thread Starter
ironbyron1
1977 CJ5
Matt
I do as much work as I feel I can handle. I agree, at 70 I don't think it would run and would smoke like Mount St Helens! I'm having someone give me a third opinion on the compression soon, hopefully today.
As for the timing. I think it jumped time when the first guy who botched the control module, kept cranking it trying to get it to run right with the module hooked up backwards.
Byron Oost
Owensboro, Kentucky
post #10 of 29 Old 02-27-2013, 07:42 AM
Matt1981CJ7
1981 CJ7
So timing has never been checked thru-out this whole ordeal? Really? I'd be hauling my CJ out of that shop ASAP. They sound like a bunch of clowns.
If you can turn a wrench, and read a repair manual, you can do about 95% of all repairs on a CJ, yourself. Just sayin'....
I know wrenching isn't for everyone, but I hate being at the mercy of untrustworthy mechanics, so I forced myself to learn how.
Matt
post #11 of 29 Old 02-27-2013, 07:51 AM
vinnyabs
1983 CJ7
I couldn't agree more Matt. I embody that statement
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #12 of 29 Old 02-27-2013, 08:00 AM
Matt1981CJ7
1981 CJ7
Vinny,
You were in the back of my mind when I wrote that.
Your situation flat pisses me off. I can only imagine how you feel...
Matt
post #13 of 29 Old 02-27-2013, 08:02 AM Thread Starter
ironbyron1
1977 CJ5
Timing has been checked but has to be advanced a LOT for it to run. I've thought for the longest time that it has jumped a tooth. It could be as simple as a stretched chain I suppose.
Byron Oost
Owensboro, Kentucky
post #14 of 29 Old 02-27-2013, 08:04 AM Thread Starter
ironbyron1
1977 CJ5
Everyone seems to jump straight to the "it wouldn't run if it had jumped time thing". I tend to agree, but maybe it would run if it only jumped one tooth and you advanced the timing!
Byron Oost
Owensboro, Kentucky
post #15 of 29 Old 02-27-2013, 08:12 AM
Matt1981CJ7
1981 CJ7
Yes, you can advance, or retard, timing to make an engine run after it has jumped a tooth, but it won't run well.
There are several examples of this documented in threads, here.
How far advanced did they set it to get it to run? And why in he!! didn't that raise concerns about the timing chain with those clowns? Ugh....
Matt
