Comp cam in 360 - JeepForum.com
post #1 of 8 Old 04-22-2011, 11:47 AM Thread Starter
kmm
Comp cam in 360
In the process of having an AMC 360 re-built, the donor motor was from a 1979 Cherokee Chief. I chose the Comp. cam 268h with timing set. The machinist had to get new retainers and locks for this motor/kit for it to work? Is this common? Anyone have first hand experience with this motor and cam kit. Chose this kit becouse of research and reccomendations from Comp.
Thanks
kmm is offline
post #2 of 8 Old 04-22-2011, 03:47 PM
lanecj5
1980 CJ5
The 268 is not a very radical cam.Nice lopy idle,very good throttle response.Small enough you can still use ac and do not need a canister to hold air for the power brakes.When you say locks,Was he refering to the locks and hold downs for the exh. and int. valves in the heads.This cam change is really straight forward...You can do this cam and lifter change in a day with air tools and one person helping you.No need to remove the heads.Just rockers and pushrods.
lanecj5 is offline
post #3 of 8 Old 04-22-2011, 04:16 PM
swatson454
1983 CJ7
I don't have any first-hand 360 experience but some Chevy Vortec heads sometimes have clearance issues between the guide boss and the spring retainers. If that's what he meant, it's no big deal.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #4 of 8 Old 04-22-2011, 05:17 PM
dharmabum
dharmabum's Avatar
Good choice on the cam, used the sane one in the 360 in my old Commando, it was from a waggy but can't remember the year off hand. I did not need to change anything special for it though but there could be some interference, doesn't sound like a big issue.
dharmabum is offline
post #5 of 8 Old 04-22-2011, 06:39 PM
mopar408
1974 CJ5
I wonder if he's talking about OFFSET retainers and/or locks to move the retainer down and top of stem up.
Have been told, and noticed after that it's true, that stems don't stick up very much at all on AMC v8, and if rocker arm hits retainer and unkeys something, bad news.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #6 of 8 Old 04-22-2011, 06:53 PM Thread Starter
kmm
Yeah it wasn't a big issue but I was just a little curious? Glad to hear it was a good cam choice. Thanks for the help and responces!
kmm is offline
post #7 of 8 Old 04-22-2011, 07:02 PM
mcmud
1983 CJ8
Bingo
The same can be said of all of the AMC Jeep engines. It reflects a mark of a good machinist/engine builder that will recommend if not insist on this modification.
mcmud is offline
post #8 of 8 Old 04-22-2011, 07:18 PM
TsCJ779
If you don't like the 268H I got a 270H for sale.
TsCJ779 is offline
Comp. Cut CJ? xulcuz Jeep CJ Forum 4 07-28-2008 03:56 PM
Pro comp 2.5 lift kamikazejeep Jeep CJ Forum 2 04-16-2007 09:14 AM
258 comp ratios tscuda Jeep CJ Forum 6 12-25-2006 06:53 PM
comp cut cormech Jeep CJ Forum 11 07-28-2006 08:23 PM
Anyone Comp cut an early CJ-5 18to80DDC Jeep CJ Forum 7 05-06-2006 07:25 AM
