comanche dana 44 - will it fit? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > comanche dana 44 - will it fit?
VIAIR compressors at ROCKRIDGE4WD!! DEALS INSIDE!50" LED CREE Light Bar Pair With Wiring KitIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-25-2014, 08:03 PM   #1
ceej7
i have an option to buy an 89 d44 out of a comanche for $200. will this be the same or close to the same wms to wms as wide track axles ? dont need it right now but the price is right and since i have an amc 20 it never hurts to be prepared!
ceej7 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 08:06 PM   #2
CSP
It's wider by about 6" over wide track CJ rear axles.
CSP is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 08:08 PM   #3
ceej7
AW MAN......... had my hopes up!
Unread 09-26-2014, 05:53 AM   #4
seabass1858
seabass1858's Avatar
1983 CJ7
you can always shorten it to a cj width and get the correct axle shafts.
seabass1858 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 07:46 AM   #5
BlueRubiconrich
your best bet is to get a Scout 2 Dana 44 rear, Ford Bronco 9" 66-77
86 CJ7 Dana 44, these have the same bolt pattern 5 on 5 1/2.
other axles but 5 on 4 1/2 Ford 8.8, Honda passport Dana 44
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline   Reply With Quote Quick reply to this message
