Anybody know for sure which model from GM to look for at the yard for an exact fit? CJ columns on ebay are to much money. The only reason I would like to know is to find a tilt.
I broke the plastic gear indicator for automatic transmissions. I thought I had depressed the clip enough before I started pulling on it. Any GM from the 80's should work for this replacement, right? The other thing I'd like to do is replace the bulb, I think it's burned out. It looks like there's a green sleeve over the bulb or is it just a green bulb? How do you remove it, press down & twist?
Removing the lock plate may hold me up because I don't know what it looks like. I found an article on how to remove it, with pictures. I'm going to go to the parts manual to see what it looks like after I enter this thread. Thanks for your help. CJ
