Colorado Emissions: High CO's (Air Fuel Mixture) slightly higher but Failed - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Colorado Emissions: High CO's (Air Fuel Mixture) slightly higher but Failed
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 08-04-2011, 05:01 PM   #1
SomerJeep
I am helping a friend get their Jeep emissioned however they have never had to have it done since they've lived outside the denver area. Now they moved and the Jeep needs to pass.
Here are the numbers:
Limits 1.20
2500 rpm = .9
idle = 1.37
How can we reduce the COs?
86cj7 laredo
SomerJeep is offline   Reply With Quote Quick reply to this message
Unread 08-04-2011, 05:06 PM   #2
LibertyJeeper
What is the timing set at?
What year is thee jeep?
Originally Posted by walkerhoundvm View Post
Just keep in mind: things are never as bad as they seem. These are jeeps, built by man and any problems you come across can be solved by man - even you! Best of luck.
Looking for axles 4.10's or higher
LibertyJeeper is offline   Reply With Quote Quick reply to this message
Unread 08-12-2011, 08:31 PM   #3
scott78cj5
1978 CJ5
Me too Friday 8/12/11: Came from Tucson a month ago, no emissions hassles there at all. Now here in Denver - an hour ago just went down in flames at the station.
Besides the numbers I need: catalytic converter and an air injection system. Then we get to:
Pass - HCPPM 2500rpm = 837.3, idle=365.1, limit 400
Fail - CO 2500rpm = 0.68, idle = 5.45, limit 1.5
NA? - CO2 2500rpm = 11.5, idle = 11.2 (there was no pass/fail indicated here)
Before the test I had the pcv and temp control switch plugged, it is/was running as good as it ever has. Just before the test I pulled over and re-hooked up those things. It started to stink and rough idle. Maybe I should have left it, but wondered if it then would be an equipment fail. Well, got one anyway.
fyi after I had got to denver and higher altitude I took my edelbrock 1404 manual choke apart about 5 times before I got the right mix of metering rods, springs, and jets. Running awesome. Based on smell at the station though, running too rich seems a certain contributor to fail. Can the hook up of pcv/temp switch made that difference? Might have failed anyway who knows. PCV, EGR, temp control switch are all new. Canister (carbon?) isn't hooked up from what I can tell.
Maybe I just do the equipment fixes then get to the other stuff.
I am doing more and more work myself but this stuff is out of my league. In the Denver area (northwest) any tips for a mechanic appreciated.
Thanks. -sm
scott78cj5 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2011, 08:33 PM   #4
scott78cj5
1978 CJ5
1978 CJ5 304. I set the timing about 6 months ago and forgot where at. Was a number recommended by mechanic. What a dork owner, I forgot the timing setting. Oh well getting sharper I guess.
Unread 08-12-2011, 08:51 PM   #5
walkerhoundvm
1981 CJ8
Originally Posted by scott78cj5 View Post
Me too
I'm surprised you didn't get dinged for the Edelbrock carb.
If I were you, I'd scratch it all and go fuel injected. THAT is something that you can do, and you're moving forward instead of backwards. It may cost you more in the short run, but you'll be nickle and dimed for the next decade if you try to go back to original. You'll still need a cat and a connected canister, but not the air tubes.
Never thought I'd recommend that, I love the simplicity of carbs, but the regs can be a headache that's not worth fighting against.
walkerhoundvm is offline   Reply With Quote Quick reply to this message
Unread 08-12-2011, 09:48 PM   #6
scott78cj5
1978 CJ5
Hey wow I have no prob with that idea. Feel the same about carbs but this:
"it may cost you more in the short run, but you'll be nickle and dimed for the next decade if you try to go back to original"
is a sobering thought. Am in Denver for good now.
(posting from phone not sure what that's gonna look like)
Unread 08-12-2011, 10:10 PM   #7
walkerhoundvm
1981 CJ8
Do a search, ask for other opinions, by all means. I was hesitant at first, but FI was the only way to stay on the roads for me. I have back-up pieces if I ever want to do a real resto, but as far as equipment that is going to last a while, a TBI kit will be easier to maintain than an old carb - both as far as parts and adjustments. I sailed through emissions, most will say the same thing.
I do miss the simplicity of the carb, though. I love to tinker and it's honestly been a little depressing over the past few months since I installed fuel injection - I haven't hardly had to look under the hood for anything!
Unread 08-13-2011, 11:01 AM   #8
Alby63
1982 CJ5
http://www.automotiveu.com/zack5gas.htm
'82 CJ5, glass body, 327, Holley Stealthram Pro 950 EFI, B&M Turbo350, Dana 44/30, Lockers, 3.73's, 6-1/2" lift, 35's, stainless mustang SLP exhaust
Alby63 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 04:56 PM   #9
scott78cj5
1978 CJ5
Fuel injection (howel tbi) should be done Wednesday, then the assault on CO emissions. I'll let you know.
Unread 09-26-2011, 07:57 AM   #10
CSP
Don't look for EFI to make the catalytic convertor requirement go away. It still has to be there.
CSP is offline   Reply With Quote Quick reply to this message
