Cold Weather Stall. - JeepForum.com
post #1 of 11 Old 10-28-2009, 04:08 PM Thread Starter
hagan39
1981 CJ7
Cold Weather Stall.
Okay so i have a 258, with a rebuilt carb. Bought the Jeep in March of this year and don't know to much. Had a weber carb and was stalling mid drive at random times and was hard to start period. I don't know enough about Jeeps to rebuild a carb so had it redone. Got the carb back and it worked great all summer long. Well weather started getting colder (ohio) and the Jeep is harder to start and starting to stall again (just shuts off when I am driving and is hard to start back up). Any ideas as to why this might be happening. Fuel filter is new and carb is set up right. Need some help because I took it out about a week ago at night and couldnt get it started again from dinner/. Pretty basic knowledge on my end so simple answers would help. Couldn't find too many similar posts so thought I would start my own, and I did search around quite a bit on JF.
hagan39 is offline
post #2 of 11 Old 10-28-2009, 04:16 PM Thread Starter
hagan39
1981 CJ7
bump......
hagan39 is offline
post #3 of 11 Old 10-28-2009, 05:48 PM
nicknoty
1983 CJ7
it sound like it is jetted 2 lean and the fast idle may need to be adjusted if you have trouble with a true cold first start. most webers need a fuel presure regulator due to the inconsistant psi out on mechanical fuel pumps.
is it a factory weber? or an after market 34/34 32/36 or 38/38
check your plugs see if they are fouled out or not i'ld change them an drive around and check what they look like after a day or 2 if they are dark you are too rich or have oil more then likely with the thicker colder air you are proly running a lean mix and the plugs will look white to light tan
also if they rebuilt the carb and set the float level incorrectly it will fuel cut under a hard throttle
i have aweber 38/38 dgas and i put it on last fall ran great but then when it got cold cold like snow it was way too lean and need to be jetted now it runs fine
83 cj7, white/pearl w/ black trim - 99'ax-15/clocked dana 300 twin sticked - 4"RC lift - HD shackles - 33X10.5 bfg mt's on micky' T 15" classic 2s - HD tierod flipped - custom bumpers with d-rings - winch - flowmaster - obd1 efi swap - 4.6L strocker with com smooth idle cam. soon to be:
rear disc brakes,front and rear tube fender flares and better sliders, 3.0L mercedes turbo diesel power
nicknoty is offline
post #4 of 11 Old 10-29-2009, 04:28 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Does your choke close when go to start it for the firs time?
Doesn't explain why it just dies though but that may be another problem.
John Strenk is offline
post #5 of 11 Old 10-29-2009, 06:21 AM
nicknoty
1983 CJ7
yes i have an electrict choke the blade should be closed at a cold start if the sensor is bad on your engine it could throw false ohms and mess the choke up if you to have electric.
it could die for a number of reasons
nicknoty is offline
post #6 of 11 Old 10-29-2009, 09:51 AM Thread Starter
hagan39
1981 CJ7
Nicknoty have the 32/36 so I will look into your suggestions. May have to go out and get myself a weber book just so I feel comfortable with what I am doing. I have read some different write ups on those regulators and also on checking the plugs so that might be the first place i look to remedie this one. Thanks for the posts guys.
hagan39 is offline
post #7 of 11 Old 10-29-2009, 09:53 AM Thread Starter
hagan39
1981 CJ7
will have to double check on the choke, didn't think about that one.
hagan39 is offline
post #8 of 11 Old 10-29-2009, 02:18 PM
1Aauto
Vendor
1Aauto's Avatar
Also although this is a simple thing,you said it was fine in the warm weather and now that it's cool it's getting harder to start.
Is the heat stove pipe connected to the air cleaner ? This will warm up the carb on cold mornings and may solve the issue if it's missing.
T
I will be out of the office on 7/24/2017 and will return on 8/7/2017. PLEASE CALL OUR SALES STAFF WITH PRODUCT INQUIRIES 888-844-3393
1Aauto is offline
post #9 of 11 Old 10-29-2009, 03:01 PM
Fjguercio
1978 CJ7
Hagan,
I have a few ideas for you but Weber Carb or any carb and "simple" do not go too well together if get the idea. I do have a few ideas for you.
CK your choke operation and that the 12V power is still on the choke tab
1... next cold start in the AM take the air cleaner off and look at choke, should be partial open.
2...Then your start procedure should be 2 full gas pedal cylces very slow, this sets the choke and pumps two swirts of gas into throat of carb. Have a helper press the gas pedal as said and you can watch. The choke should set full closed and when you start up HIGH Idle should be 1500 rpms in warm summer and 1800/2000 rpms when colder like later fall & winter.
3.. Choke Plate should open with the 12V to the tab on choke... This is a bimetal spring and the 12V makes it hot over time like a mini heater and gradually opens the choke. So after 1 min of HIGH Idel tap the pedal to rev engine some 2500 or so just brief. This will knock the HIGH Idel down some. After 3-5 min that choke should be all the way open and may take the gas pedal rev to release the cam/High Idel.
4.. You may have a water jacketed manifold... Coolant heats this up
Also then there is a electric heater under the carb, this helps too... AFter 2-3 min of running feel this disk heater, should be warm to the touch and the rest of intake will be cold from fuel evaporation. If you have the water jacket intake both these will help a great deal during cold mornings.
5.. If you have a heat rizer manifold... it needs to be lubricated so it moves freely as regular PM. There is also a bimetal spring on one side to make it work right. So ck that too.
Webers need the Low Pres Holley Regulator, only get the holley one. The other brands are garbage. You will see this in the link too.
6.. I would ck your plugs to ck each cylinder is working/fire and good general way to see how things are working. The link at the end will have spark plug reading guide with pics.
7.. I would consider the TEAMRUSH upgraded cap & rotar.... esp if you have a alumium terminal cap now.... I bet you do... alumium oxides are not conductive and will mess your igntion up.. hard start and stalls. So maybe time for Tune UP Parts... TEAMRUSH all the way. Do your aux grounds too... All in the write up below.
I do not feel you will be too lean with a Weber 32/36 if anything they are normally over rich. Looking at your plugs will tell you. I would not adjust your carb as for settings till you get your ignition, Cap, grounds and stuff done first. You can verify the screw setting Turns but put them back to start and record in notebook.
From my experience of having lots of guys post like you this is generaly several little things that can contribute to poor running. Heck you fuel filter could even be pluged if you do not know when it was changed last.... change it.
The Weber Tune & Jet Change will also show you how to ck and verify your WEber e choke is working right. Show how to tune and so forth
http://www.jeepforum.com/forum/f8/we...-258-a-631105/
Fjguercio is offline
post #10 of 11 Old 10-29-2009, 03:41 PM
BioTex
1979 CJ7
FJGUERCIO,
I know this is a picky point, but you stated:
"The choke should set full closed and when you start up"
Actually it is a tad bit open. You should be able to insert an 1/8" drill bit between the choke plate and carb inlet front wall (for lack of the correct part name). Completely closed would shut off all air.
Eric
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #11 of 11 Old 10-29-2009, 05:09 PM
Fjguercio
1978 CJ7
Originally Posted by BioTex View Post
FJGUERCIO,
Eric
BioTex,
Just took a peek at my Weber 34 not the Posters 32/36 but it is a 2 barrel Carb and the Choke Plate does snap closed all the way. Choke only covers primary side, not sure if High Idle opens the secondary or not. Mine works great.
I did not write the Choke Set actually there was a very good link on that WEBER CHOKE SETTING and I just refer readers / posters to that. It was well done. You can both look there if you want more info.
I have heard the small drill bit gap on choke setting many times. Do not remember if weber uses that or not.
The poster said his skills are weak so not sure if would catch that or not. Cking the general working function is VERY important at this time. Same with cking each cylinder plugs and doing the aux grounds.
Thanks again,
Clutch will not engage in cold weather redcj7 Jeep CJ Forum 5 05-20-2009 09:50 AM
Cold weather oil in L-134 PaulS Jeep CJ Forum 1 12-21-2008 09:24 PM
cold weather, stuck in gear awalp Jeep CJ Forum 10 12-19-2007 11:44 AM
TBI run and stall nightstalker5.0 Jeep CJ Forum 2 12-16-2004 04:51 PM
Cold/ Wet Weather Starting Problem paypwip Jeep CJ Forum 2 03-06-2003 08:15 AM
