Cold weather oil in L-134 - JeepForum.com
post #1 of 2 Old 12-21-2008, 09:15 PM Thread Starter
PaulS
1949 CJ3A
What oil would you use in a 1949-ish L-134 flathead engine, when the outside temperature is -30C (-22F)?
I tried to start the Jeep today in those temperatures, but the battery was toast so nothing happened at all when I pressed the starter button...
But since there was no block heater on, I don't know what would have happened if I had been able to turn it over. I haven't changed the oil since I got it in the summer (I doubt it's gone 20 miles in that time), so I don't even know what's in there right now. But the PO lived in warmer climes--rarely dropping below -10C (+14F).
I put a battery warmer on it, and next time I go out to the acreage, I'll bring along a battery charger. Between those, I should be able to turn the engine over. But I should probably put some light weight oil in it, too. What rating would you suggest? I know that modern cars say to use 5W30 all year, and that seems to work fine in all newer cars I've owned, but a flathead is a different beast!
-Paul
PaulS is offline
post #2 of 2 Old 12-21-2008, 10:24 PM
Ridin' Around
Paul, I would suggest looking at Amsoil's HDD 5W-30. It is listed in their diesel oil category but has a high level of ZDDP additives that the flat head will like and be good through the warmer weather. A second option would be the AMO 10W-40, it is also a high ZDDP oil and will go a little heavier in weight while remaining a highly flowable oil in the cold. The pour point is -44*c. Hope that helps.
Ridin' Around is offline
Cold Weather Stall. hagan39 Jeep CJ Forum 10 10-29-2009 06:09 PM
Clutch will not engage in cold weather redcj7 Jeep CJ Forum 5 05-20-2009 10:50 AM
cold weather, stuck in gear awalp Jeep CJ Forum 10 12-19-2007 12:44 PM
Wet Weather Problems Mike78cj7 Jeep CJ Forum 6 12-02-2006 10:19 PM
Cold/ Wet Weather Starting Problem paypwip Jeep CJ Forum 2 03-06-2003 09:15 AM
