cold start with mc2100 question - JeepForum.com
post #1 of 6 Old 03-18-2014, 11:53 AM Thread Starter
neal90
1982 CJ7
So with all the help I have received from everyone the jeep is running very well with the new carb... except when cold. When I first start the jeep it turns over and starts but the ideal is only around 450-500 rpm (and than around 650 when warmed up) I have a manual choke that I just installed I have also made sure its working correctly, but there is no change in the rpm if the choke is open or closed. Is there some kind of adjustment on the carb that I'm missing on the choke side of the carb???
neal90 is offline
post #2 of 6 Old 03-18-2014, 12:21 PM
scrapman
Yep, sounds like you haven't set the fast idle cam adjustment, or are not depressing the gas pedal fully after you set the choke to allow the linkage to get to the fast idle cam adjustment. Page 26 of this link: http://street2mud.com/webfiles/MC-21...%20a%20258.pdf
shows the linkage.
scrapman is offline
post #3 of 6 Old 03-18-2014, 03:56 PM Thread Starter
neal90
1982 CJ7
ok I see the fast ideal cam and I closed the choke and made the adjustment and with the choke closed I set it to 1000 rpm. I opened the choke and gave the jeep a little gas and the rpm went down to 650. So that worked but when i closed the choke and started the jeep again it seems like the choke won't close enough to engage the part of the fast ideal cam the steps up the rpms. Im not sure what I'm doing wrong
neal90 is offline
post #4 of 6 Old 03-18-2014, 04:37 PM
jeepwhore
You have to press the pedal to the floor, pull the choke, then release the pedal if you want to engage the high idle with a manual choke.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #5 of 6 Old 03-18-2014, 05:23 PM Thread Starter
neal90
1982 CJ7
Thats what I was thinking thanks
neal90 is offline
post #6 of 6 Old 03-19-2014, 07:08 AM
Mike Romain
You also want the fast idle rpm to be about 1800. That makes the next step down about 1200-1300 and then idle.
Mike
Mike Romain is offline
