Cold Start - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cold Start
Black Friday Sale - Deep Discounts from ExtremeTerrain.com6th Annual, Beat Your Wife to the Credit Card Sale!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-13-2014, 11:56 AM   #1
thirstybob
Junior Member
Cold Start
Brrrrr! 17 below this morning and she started but she sure didn't want to. I ended up having to prop the choke plate open about a 1/4 of an inch and pumped the pedal about 8 times. Is it just the cold or is my choke not adjusted properly?
thirstybob is offline   Reply With Quote Quick reply to this message
Unread 11-13-2014, 11:58 AM   #2
cmsorey
Beach goer
cmsorey's Avatar
Its the cold buddy, lol chokes on anything will give ya those problems in the cold
'12 Jeep wrangler
'05 Wrangler Rubi
cmsorey is offline   Reply With Quote Quick reply to this message
Unread 11-13-2014, 12:17 PM   #3
I6CJ7
Sound like your choke isn't adjusted just right. Doesn't matter much how cold it is, i pump my pedal once, choke kicks in and high idles at around 1200rpm i believe. Your choke butterflies should be closed when starting cold, less air, more fuel, then they gradually open as it warms up. Did you have to prop open the throttle plates you mean?
A spray of ether down the carb would help with severe cold starts though, and make sure your battery/ignition is getting a strong spark.
I6CJ7 is offline   Reply With Quote Quick reply to this message
Unread 11-13-2014, 12:54 PM   #4
thirstybob
Junior Member
It was the throttle plate that I propped open. I suspected the choke wasn't adjusted correctly.
Unread 11-14-2014, 11:20 AM   #5
klearbrook
1979 CJ7
I've had the same problem. It was recently adjusted (idle and choke), but fighting me to start once it got colder a few days ago
klearbrook is offline   Reply With Quote Quick reply to this message
