Cold engine racing - JeepForum.com
post #1 of 4 Old 11-28-2013, 07:55 PM Thread Starter
wsmutch
Cold engine racing
I have a CJ-7 with the 258 IL6 and MC2100 carb with most of the pollution gear removed. When I start it it idles a little fast, but after a few minutes it really revs up and stays at high revs for quite a while, in fact I always have to kick it down with the gas pedal because I'm afraid of damaging the motor. Once warmed up it idles fine. I can't start it and let it warm up while I do get ready for say work. Is there an adjustment for the cold idle? Pictures would be helpful too please.
wsmutch is offline
post #2 of 4 Old 11-28-2013, 08:26 PM
capt205
1983 CJ7
Choke idle needs adjusting. More than likely, the screw on passenger side of carb behind the choke. Adjusts from the back side of carb
capt205 is offline
post #3 of 4 Old 11-29-2013, 03:59 AM Thread Starter
wsmutch
Thanks, I'll try that. It's been below freezing here for days, and it won't get much better anytime soon.
wsmutch is offline
post #4 of 4 Old 11-29-2013, 04:08 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
How fast is "it really revs"? Have you taken an RPM reading?
A higher than usual idle is normal when the choke is engaged, usually around 1500-1800 RPM.
"Kicking it down with the gas pedal" is also normal operation for a carb'd engine.
Matt
Matt1981CJ7 is offline
