cold air intake - JeepForum.com
post #1 of 7 Old 04-21-2009, 09:30 PM Thread Starter
JeffMcBusa
1979 CJ7
cold air intake
I suppose most have found another way hanging cold air intake,or fre
sh air Please and share with me how you did this. I am comletely missing the tube to the carb cover, on a 1979 Jeep cj AND AN SUCKING ENGINE COMARTENT FUMES INO THE ENGINE
Thanks
Jeff
JeffMcBusa is offline
post #2 of 7 Old 04-21-2009, 09:32 PM
PhatForrest
Drink much?
92 YJ, 2.5 l/o, 4" Lift, 33" Super Swampers, Superwinch EPi9.0, Aussie Locked Dana 30, Uniden pro510xl CB and Firestik antenna, Hi Lift, Tuffy Center Console, Miller Lite tap handle shift knob, 40mm ammo can tool box, chains, straps, etc. - Sold to a good home
2006 Wrangler LJ.
PhatForrest is offline
post #3 of 7 Old 04-21-2009, 10:03 PM
keith460
Jeep. There's Only One
keith460's Avatar
Originally Posted by PhatForrest View Post
Drink much?
LOL
1984 CJ-7 Renegade
keith460 is online now
post #4 of 7 Old 04-22-2009, 05:06 AM
Mike Romain
On some Jeeps, they put a fresh air or ram air scoop right beside the rad, just above the bumper. On the later ones they stopped doing this. Too many blown engines I would guess.
The problem with a ram air scoop is if you get a bow wave when crossing a puddle, the engine can gulp a mouthful of water which has a tendency to blow piston rods out the sides of blocks...
Mike
Mike Romain is offline
post #5 of 7 Old 04-23-2009, 08:52 PM
CJhollic
1980 CJ7
Thecarb adapter came from JAM engineering, everything else from AutoZone
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #6 of 7 Old 04-24-2009, 03:26 AM
GPER
1979 CJ7
Mine uses outside air
GPER is offline
post #7 of 7 Old 04-24-2009, 04:14 AM
jscherb
I use a TJ air box, and it is grabbing cold air from the grille shell using the stock bellows tubing, see the lover left corner of this photo.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
Cold Air Intake 85-CJ7 Jeep CJ Forum 3 05-11-2009 04:08 AM
CJ cold air intake? nevermind05 Jeep CJ Forum 4 11-25-2007 11:29 PM
Cold air intake? parsons125 Jeep CJ Forum 1 11-17-2007 02:34 PM
Cold air intake for CJ? goat24 Jeep CJ Forum 17 03-27-2007 10:35 AM
Cold Air Intake ClarkGriswold Jeep CJ Forum 3 02-04-2007 08:16 PM
