Coiz 1979 CJ7 Frame Off Resto; picture crazy - Page 87 - JeepForum.com
 2Likes
post #1291 of 1946 Old 03-17-2011, 08:47 PM Thread Starter
Coiz
1979 CJ7
Originally Posted by Jim1611 View Post
Great idea Mike. I have a feeling you're enjoying this part.
It is kind of fun. Look what I picked up for $9.99 at F&F.
One thing I've noticed is that even the 6" receiver is too long. If I install it like a normal hitch, with the pin on the outside of the bumper, it will be sticking out way too far and look funny. If I move the hitch pin to behind the bumper, it will be too long and I will have to cut a couple inches from the end so it doesn't hit the front crossmember. This also means any slide in hitch would also need to be shortened by the same length to fit.
I think the answer is to drill new hitch pin holes closer to the end so I can install the receiver further back but the pin will still be in front of the bumper. I'll still have to cut an inch off the end of the receiver so it clears the front crossmember but with the hitch pin holes moved toward the end, any normal slide in hitch will fit without modification it just wont be slid in quite as far as normal.
Mike
Coiz is offline
post #1292 of 1946 Old 03-18-2011, 06:47 AM
Jim1611
Jim1611's Avatar
Great buy on the receiver Mike.
I think you're on the right track with drilling a new hole. It would be handier to get to in front of the bumper too. I'm sure you've already looked through your surplus steel and have parts to do it but I'd brace the backside of that up the same way you did with the clevis tabs.
Let's see....is there anything else you need to add besides the reciever? I can't think of anything.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #1293 of 1946 Old 03-18-2011, 09:21 AM
mtbtweety
mtbtweety's Avatar
1982 CJ8
You likely won't use that receiver for anything other than bike mounts or canoe mounts, or maybe an occasional retrieval point. I doubt you'll back around with a trailer attached to it, so I wouldn't be overly concerned about cutting any length off of it, or redrilling the pin closer to the end. It's not like you're gonna rip the pin out. Great work on the bracing welds!
mtbtweety is offline
post #1294 of 1946 Old 03-18-2011, 10:58 AM
CopperCJ7
Mike: Please excuse my blunt factor...
I think your machine is a work of art and is aesthetically beautiful. That said, I really have to say that I think that front bumper is too "Mad Max" for the looks of your custom chariot. I mean, the rig is built for speed and deserves a front bumper with a little more style and less "scrap-yard." It just looks out of place.
You know I mean no offense by this statement. It's just what I feel.
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #1295 of 1946 Old 03-18-2011, 05:19 PM
Jim1611
Jim1611's Avatar
Mike!!! I've thought of something else.
This may be overkill but. I was looking at how your tubes are welded onto the topm of the bumper and was thinking they could be breaced up a bit and not much trouble in doing so. I was thinking about running a diagonal brace, well you're gonna do it, from the main tube back down to the winch plate. You could tie it all together, bumper and winch plate, or you could weld the brace to the bumper tube and make a bracket bolt it to the plate.
Okay I think that's about all I can think of for you to keep doing.
My build thread
Jim1611 is offline
post #1296 of 1946 Old 03-20-2011, 11:14 AM Thread Starter
Coiz
1979 CJ7
That's what I was thinking. There will never be an extreme load on the receiver so an inch or two cut off the end won't hurt anything. It will be plenty strong by the time I'm done with it I'm sure.
No offense taken. I wasn't too keen on the front bumper when I first bought the Jeep in 1994 but it came to grow on me. After having "used" it a couple times it proved to be a sturdy and practical unit. I'll have to refer you to my last comments in post #1247.
You have to remember this rebuild started as a "I'll replace the front fenders and give it a quick paint job and be done". I was figuring in the $4-6k range from the beginning (and yes that was doubling my original estimate). I'm sure I have doubled that $$$ amount and I'm not even done. So far I've spent ~$40 beefing up this bumper with the clevis mounts and receiver. That's a lot cheaper than a new bumper, I have to draw a line somewhere.
Unless I see a front bumper that just jumps out at me as a must have, I'm pretty sure I'll be sticking with this one for a while. What's nice is I have the option to easily change something like that at any time. I'll have to admit that I have not searched for any other front bumpers though.
This may be overkill but. I was looking at how your tubes are welded onto the top of the bumper and was thinking they could be braced up a bit and not much trouble in doing so. I was thinking about running a diagonal brace, well you're gonna do it, from the main tube back down to the winch plate. You could tie it all together, bumper and winch plate, or you could weld the brace to the bumper tube and make a bracket bolt it to the plate.
I see what you're saying and think your starting to venture into the Mad Max realm stated earlier. If I were using the Jeep to plow trails through the jungle or run down animals I could see how that could be useful. I think that may be stretching a little too far into the overkill range. Lets see where I'm at after the receiver is installed.
Mike
Coiz is offline
post #1297 of 1946 Old 03-20-2011, 06:35 PM
Jim1611
Jim1611's Avatar
Mike I'm not making all of these suggestions for you anyway. Remember the deal?? Sliders, belly skid, I do all of the work and you leave me the CJ for 10 years.
Looking forward to the receiver install.
My build thread
Jim1611 is offline
post #1298 of 1946 Old 03-20-2011, 07:44 PM
Gunsmith_207
1979 CJ7
Mike, if Jim don't quit giving you ideas this thing will never be done. I like the addition of the winch to the bumper, looks awesome. I home to weld with my new welder half as good as you do.
Gunsmith_207 is offline
post #1299 of 1946 Old 03-20-2011, 09:07 PM Thread Starter
Coiz
1979 CJ7
Front Bumper Receiver
^^^ Thanks Gunsmith, make sure you show us what your welding.
So here is a picture of the front bumper with the 6" long receiver I had bought for $10.
I measured out the centerline of the bumper and marked everything off for the cutout for the receiver. I drilled holes in the corners and used a die grinder to cutout the section.
After the hole was cut, I inserted the receiver and cut it to the correct length. In this picture you can see how far forward I moved the holes for the pin.
This is with it pushed all the way back, it actually ended up about a 1/8" forward from this spot.
I made sure the bumper was at the correct angle of 90* to the ground.
I tack welded the receiver in place and got it pretty close. I had to use a hammer to tap it into the correct alignment.
Bumper is at 0* to the ground, ie. flat.
I made sure the receiver was set at the same angle before final welding. I also measured side to side to make sure the receiver was as square as possible.
I welded it in from the back side. Not super pretty welds but they should have good penetration.
Reinforcements are coming up next.
Mike
Coiz is offline
post #1300 of 1946 Old 03-20-2011, 09:20 PM
Davidnex
1979 CJ5
Love the Angle Master.. I'm always working without a level floor
79 CJ 5 Frame up Build
http://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline
post #1301 of 1946 Old 03-20-2011, 09:35 PM Thread Starter
Coiz
1979 CJ7
The angle master is a wonderful tool. It might be a little pricey at the ~$250 price range but it is essential when making mods such as this and is priceless when checking driveling angles. The carpenter style angle masters you get from Sears are very good, especially for the $15 they cost, but having a digital readout down to the .0* is simply awesome.
Mike
Coiz is offline
post #1302 of 1946 Old 03-20-2011, 09:39 PM
Davidnex
1979 CJ5
Mike where did you get yours???
Davidnex is offline
post #1303 of 1946 Old 03-20-2011, 09:50 PM Thread Starter
Coiz
1979 CJ7
Mine is employer supplied. You can buy them in various places but if you are seriously considering one, send me a PM and I can probably get you one at a discount.
Mike
Coiz is offline
post #1304 of 1946 Old 03-21-2011, 06:31 AM
Jim1611
Jim1611's Avatar
Nice work Mike.
My build thread
Jim1611 is offline
post #1305 of 1946 Old 03-21-2011, 05:07 PM Thread Starter
Coiz
1979 CJ7
Receiver Reinforcement
I finished welding the front side of the receiver and yes I chiseled off that little ball of slag.
I figured I had used pieces of my old engine mounts for reinforcements on everything else on the front bumper, I might as well use what was left for the receiver portion. The two remaining pieces were marked at 45* on the ends and trimmed. One side is just a little longer than the other, that will be the bumper side of the gusset.
I ended up with some pretty stout little gussets that are the perfect size to tie in the sides of the receiver to the back of the bumper.
Here are the gussets sitting in place ready to be welded in but I wanted to get a coat of weldable primer on everything first.
In typical overkill fashion I decided to also add small gussets on the top and bottom. I used the piece I had cut from the end of the receiver and trimmed it down to fit. I needed to narrow it down so I cut about a half inch from the center and welded it back together.
Here is where it will sit to support the bottom of the receiver. I made a smaller one to sit on the top side.
I tacked in one side solid.
The other side in place.
Top of the passenger's side all welded in.
The top of the driver's side all welded in.
Flipped it over and started welding the bottoms of the gussets.
Here is the other side. I was welding right to left and ran out of wire a 1/4" too soon. I wish my welder would hold more than 2# spools of wire. I think that makes 32# through the HF welder with no problems to date.
Finished welding and now I just need to clean it up for painting.
So here is the finished front bumper with no other major modifications planned. As a matter of fact, that should be the last of the welding projects for the Jeep unless I come up with something else to build. I just need to get it and the winch plate painted. Yet another thing I have to wait on warmer weather for.
Mike
Coiz is offline
cj7 , frame , paint , welding
repairing rear frame on CJ7 (picture request) OlivergreenCJ7 Jeep CJ Forum 7 08-13-2009 08:43 AM
1979 Jeep CJ5 (just a picture, no tech.) mmerlina Jeep CJ Forum 20 05-15-2009 02:09 PM
1979 CJ7 Grille to Frame mount (Help) jpnkavu Jeep CJ Forum 3 10-15-2006 12:21 PM
1979 CJ5 Frame Up Restoration cyoungone Jeep CJ Forum 3 02-22-2003 08:30 PM
Frame off Resto. WarnRocker79 Jeep CJ Forum 4 03-12-2002 10:12 AM
