Coiz 1979 CJ7 Frame Off Resto; picture crazy - Page 127 - JeepForum.com
 2Likes
post #1891 of 1943 Old 03-03-2013, 02:06 PM Thread Starter
Coiz
1979 CJ7
Originally Posted by mburgess00 View Post
I know this thread is a little old, but I still wanted to comment.
I recently acquired a '79 cj5 and your build is an inspiration. Thanks so much for spending the time to put so many details on this site.
How are you enjoying the fruits of your labor these days?
Matt
Thank you for taking the time to read it and post. It was a lot of work but well worth it in the end. I very much enjoy driving the CJ whenever I get the chance.
Originally Posted by XJAbuzer View Post
It would be interesting to see some wheeling pics or videos. Maybe just an updated pic of what it looks like 4 months later. Love this CJ!
Nothing new to see as of now, it is just parked in the garage hiding from all the sodium chloride Illinois loves to use. I hope to get it out and take a wheeling trip or two this summer.
Originally Posted by Matt1981CJ7 View Post
Is that the dreaded "Jeep Lean" I'm seeing on the famous Cobra CJ, or does Mike need to loose some lbs?
Matt
Ha, I knew most of that was from camera angle but you made me go pull out the tape measure. I do have a 1/4" lean to the driver's side but that's not really too bad. Certainly not from my weight, I come in at a 150# soaking wet.
Originally Posted by Renegade82 View Post
I just noticed the earlier (oct.) posts of the show. Congrats Mike, it was a well deserved trophy. I also really love that blue bobtail Bronco.
Thanks, that Bronco was pretty cool.
I've got a couple things I still need to do to the CJ but need to work up the motivation to get them done, that and it's 30 degrees in my garage right now. I need to fix a small oil leak coming from the low oil sensor on the side of the oil pan and I still need to get my 4x4 light wiring finished up. I also need to get my Hi-Lift and other accessories mounted to the rear swing-out bumper.
Maybe it's time to sort through the pile of receipts and see how much this thing actually cost me.
Mike
Coiz is offline
post #1892 of 1943 Old 03-03-2013, 05:02 PM
Jim1611
Jim1611's Avatar
[QUOTE=Coiz;15070465]Thank you for taking the time to read it and post. It was a lot of work but well worth it in the end. I very much enjoy driving the CJ whenever I get the chance.
Maybe it's time to sort through the pile of receipts and see how much this thing actually cost me. [/QUOTE]
Nope. It's time to get it dirty.
Jim1611 is offline
post #1893 of 1943 Old 03-14-2013, 05:32 AM
Cabe75
1973 CJ5
Coiz,
I have spent the better part of 20 hours ready every post on your build.
All I can say is WOW. The dedication and perseverance that went into this build is second to none.
I only hope one day I can pull off what you have accomplished. I just need to convince the wife first!!
Cabe75 is offline
post #1894 of 1943 Old 04-28-2013, 01:53 PM
Havasu Living
Havasu Living's Avatar
1980 CJ7
Looks like your running 2.25" dual exhaust. I'm redoing mine to dual also. I've searched the thread for specific pics of how you routed the p-side from the headers past the trans and t-case. When I had this done 4 years ago the shop routed the p-side under the oil pan and then into one exhaust. Any pics would be much appreciated.
80 CJ7 5.0 Dual Exhaust, T176, D300, D30 w/ true trac, AMC 20 w/ ARB 4.56 gears, York OBA, Hydroboost
Havasu Living is offline
post #1895 of 1943 Old 04-29-2013, 03:26 PM Thread Starter
Coiz
1979 CJ7
Originally Posted by Cabe75 View Post
Coiz,
Hey, thanks for taking the time to read the build and post a comment. I'm sure your CJ will turn out just as nice.
You're right, I don't really have any good pictures of that side posted or in Photobucket. I'll have to dig through my old folders to see if I can find some for you. Or I can take some as is but it would be a whole lot easier to see without the body installed. It was mostly a straight shot back with over an inch of room available on each side between the frame rail and transfercase.
This picture kind of shows it but I will see if I can find a better one for you, specifically after it was cleaned up.
Mike
Coiz is offline
post #1896 of 1943 Old 04-29-2013, 04:42 PM
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Aren't we all in the same place
-Dave
AustinCJer is offline
post #1897 of 1943 Old 04-29-2013, 05:29 PM
Havasu Living
1980 CJ7
Ok is see how you ran it back. But.....how close is the front d-shaft to the exhaust? If you have a pic of the header/starter/front d-shaft/exhaust pipe, that area. Thanks.
post #1898 of 1943 Old 04-29-2013, 07:08 PM Thread Starter
Coiz
1979 CJ7
Here you go. This one shows you frame and TC clearance.
From the front looking back.
From the back looking forward. That picture is a little deceiving. It cannot contact the exhaust under full compression.
Mike
Coiz is offline
post #1899 of 1943 Old 05-03-2013, 10:51 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I've got all the wiring cleaned up. I basically laid it out on my driveway as if it was in the Jeep. Here is the harness that starts by the fuse box and goes to the rear.
I stripped the convoluted tubing back to get to all the wires. I couldn't remove it completely due to the grommet at the rear.
Up near the connector was a ball of wires all tied up with a small four pin connector. One wire was red with a fuse holder and the rest went toward the rear of the Jeep. They were never hooked to anything near the fuse box and they ended about half way to the rear. I am guessing they were for the dome lamp but don't know why there are four wires. I took them out.
The main engine harness is on the right side and the head light harness is on the left. I had already stripped most of the engine harness half.
The harness was pretty dirty.
After reading different things, I decided to clean it with Marine Clean. Sprayed it on diluted and wiped it down with a sponge. I used a tooth brush on the connectors. It cleaned up great. Notice the relays near the PCM connector, I am relocating those to under the hood so it takes up less space under the dash.
Here is the entire under hood harness striped and cleaned. I dried them off with a towel and strung them across the bed of my truck to dry in the sun for the rest of the day.
Here is the dash harness.
Picture of the fuse box. The white wire controlled my 3 way switch to the cooling fan. I'm pretty sure I remember the PO had wired the reverse lights to the dome light switch because I could turn them on and off while wheeling at night. I plan on fixing that correctly so the transmission controls the reverse lights. Also notice the jumper wire. I never knew why that was there and why my volt gauge was hot at all times. When I pulled the ignition switch I found the feed to the yellow accessory wire was folded over and not making contact to the circuit. Not knowing what was wrong the PO must have ran that jumper to get the power to the other side of the box.
A picture of the back side of the fuse block.
I got it cleaned up and most of the wires sorted. I'll finish taping them off once it is installed and I can determine the exact location and length of everything.
Hey Mike, do you by chance have anything written down as to which wires go to which pins in the bulkhead connector? I'm trying to wire in a few necessities so I can start driving this thing.
Specifically, I'm looking for a wire that is hot while the key is in "run" so I can prime my fuel pump. I found the light blue wire on top of the steering column for the starter, and that's basically it. Everything else would require me to take my cage / dash down.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #1900 of 1943 Old 05-03-2013, 04:41 PM
Havasu Living
1980 CJ7
Thanks, btw, what headers are you running?
post #1901 of 1943 Old 05-04-2013, 08:04 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Grew02, if you are going to use a relay for the fuel pump, then why not just follow the wire from the coil to the bulkhead connection? That is hot in run.
What setup are you doing, because Ford uses the ECU power the fuel pump relay, so you shouldn't need a special wire for it.
Rick
Cutlass327 is offline
post #1902 of 1943 Old 05-04-2013, 10:47 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I am trying to figure out which wires go where for the stock harness and bulkhead connector. Right now I don't even have the bulkhead connector in the Jeep. I wired in a 3 position switch to start the motor from the engine bay (through the relay), and I'm trying to figure out which wire on the stock harness is the coil wire, so that I can use my column key instead of a switch.
So by this diagram, I need to figure out which pin on the bulkhead connector is the red (battery) wire, and also the yellow ("run") wire.
(Warning, very large file, almost 1MB.)
http://imageshack.us/a/img833/7328/c...on7273cjwi.jpg
Andy, KD8EIA
Grewe02 is offline
post #1903 of 1943 Old 05-24-2013, 10:58 AM
turbogus
1978 CJ5
Congrats Mike on the award and thanks again for all your help !
I wish I hadn't looked at your build thread now, I was once kinda proud of 'Black Betty' but now I feel like I'm polishing a turd.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #1904 of 1943 Old 08-15-2013, 03:19 PM
jhughes2013
1977 CJ7
Sorry to bring up an older post. I ran my exhaust the same way. Mufflers are side in, opposite side out. Fits just barely. I also centered the fuel tank and ran 3.5" tips out the back. I wouldn't recommend the 3.5" tips as there is only .25" clearance on either side of each tip. Also, with the 2.5" pipes it took me a long while with a torch and a hammer to make those suckers fit around the front of the fuel tank without touching. In the end it was well worth it. I love the sound. I also have cats just after the headers to muffle the sound since the entire exhaust system of a jeep is less than 6 feet long... Sorry for the non-specific pics but these are the only ones I have access to at the moment.
1075667_1382065138683284_1616473376_n.jpg   942385_1382065155349949_1830708727_n.jpg
'77 CJ7, LS1, NV4500/D300, Ford 8.8, 4" of lift, 33x12.50 BFG ATs...
jhughes2013 is offline
post #1905 of 1943 Old 08-15-2013, 06:34 PM
turbogus
1978 CJ5
Very Sweet Jeep Coiz! Well done my friend! I dig how those bikini tops set off our CJ's given the height of the main roll bar on mine it gives it that forward canted mean look.
Also on my bikini to spread the top a little more to cut down on turbulent flapping I would the aft ties around the downtubes of the cage., just a thought.
turbogus is offline
cj7 , frame , paint , welding
repairing rear frame on CJ7 (picture request) OlivergreenCJ7 Jeep CJ Forum 7 08-13-2009 09:43 AM
1979 Jeep CJ5 (just a picture, no tech.) mmerlina Jeep CJ Forum 20 05-15-2009 03:09 PM
1979 CJ7 Grille to Frame mount (Help) jpnkavu Jeep CJ Forum 3 10-15-2006 01:21 PM
1979 CJ5 Frame Up Restoration cyoungone Jeep CJ Forum 3 02-22-2003 09:30 PM
Frame off Resto. WarnRocker79 Jeep CJ Forum 4 03-12-2002 11:12 AM
