Coiz 1979 CJ7 Frame Off Resto; picture crazy - Page 121 - JeepForum.com
 2Likes
post #1801 of 1944 Old 03-07-2012, 01:41 AM
MrBeast
1980 CJ7
Mike, I just skimmed through all 120 pages. I am pretty impressed with what you have done with what you started with. Id have scrapped that tub and found another. Your hard work has definitely paid off. Very good attention to detail.
"He used to be a pretty nice feller, now he's a welder"
AMC 304 V8, NV4500, Dana 300, Dana 44, 9 inch, M.O.R.E. SRS, YJ tub.
AT3 US Navy 1999-2003
Cum catapultae proscriptae erunt tum soli proscript catapultas habebunt
(When catapults are outlawed, only outlaws will have catapults)
MrBeast is offline
post #1802 of 1944 Old 03-19-2012, 04:52 PM
jeepcj7er
1983 CJ7
You put a ton of work into that thing. Looks great! How did you relocate the bolts on the inside of the dash for you 5 in speakers? How does it sound, any vibrations from the sound hitting the slotted dash?
jeepcj7er is offline
post #1803 of 1944 Old 03-20-2012, 04:43 PM Thread Starter
Coiz
1979 CJ7
The stereo sounds great and I don't get any type of vibrations out of the dash or speaker grill slots.
My dash had the driver's side speaker slots cut in by the previous owner. The passengers side looked stock and already had a 5.25" speaker installed when I bought it. So I didn't have to make any modifications to fit the 5.25" speakers into the dash. I did replace four of the studs for one of the speakers but only because they were a different thread than the other side and all beat up. I'm not sure if that's something the previous owner did or if it was factory. I was always under the impression that 5.25" speakers were the stock size for the CJ.
This thread might help you out.
Mike
Coiz is offline
post #1804 of 1944 Old 03-20-2012, 06:29 PM
_Ross
I started reading through your build. Amazing work and lots of great techniques that I will hopefully employ properly when I get started next month. Also, I guess it's time to try and brew some beer
84 CJ-7 4.2Lw/ bolt ons, T5/300, 30/20, 4" skyjacker(newest money pit)
83 CJ-7, 360w/ bolt ons, TH400, SOA, 38.5X15 Mudders(sold)
79 CJ-5, stock(sold)
_Ross is offline
post #1805 of 1944 Old 03-20-2012, 08:34 PM
jeepcj7er
1983 CJ7
[QUOTE=Coiz;13273050]The stereo sounds great and I don't get any type of vibrations out of the dash or speaker grill slots.
Thanks for the help! Ill probly just get the centra pod cause my dash leaks water when it rains, but thats good to know that i can fit 5.25s when I fix the leak.
post #1806 of 1944 Old 03-21-2012, 08:12 PM Thread Starter
Coiz
1979 CJ7
Thanks for taking the time to read through it. I just caught myself reviewing almost 40 pages in the last two hours. Ahh, the memories.
Not sure if you're still in Iraq or back home but let me know if you ever want some help on the Jeep once you start your work on it, I'm less than an hour away.
No problem. Any idea if your leak is from the windshield to cowl seal or from the fresh air box to cowl seal? The fresh air to cowl seal is probably the easier to fix.
Mike
Coiz is offline
post #1807 of 1944 Old 03-21-2012, 08:36 PM Thread Starter
Coiz
1979 CJ7
I just realized I never responded to a couple comments.
Originally Posted by Jim1611 View Post
Well now that it's been offpavement, as CJs should be, when can we see some serious mud hangin all over it?
Hell yeah Jim, I am ready to get this thing muddy. Know anyone with a pond I can drive through?
Originally Posted by ffisher55 View Post
Mike,
I've followed your build with great interest, and have learned a great deal. Your skills and competence in several areas is very obvious.
I'd like to pass on a trick I learned years ago from a PPG marketing rep regarding the use of paint strippers. In addition to scuffing the surface as you suggested, he said to put a thick coat of the product on the surface to be stripped, and then cover it with a layer or two of newspaper, causing the fumes to "stew and brew", without drying as quickly. Give it some time to work, and as a bonus, the paint sticks to the paper and is easily disposed of. Usually one application does the trick, which is good, as there are diminishing returns with subsequent applications.
Also, when I saw you add the receiver to the front bumper, I thought that would be a natural spot for a license plate.
Again, congratulations on your one of a kind CJ!
Frank
Thanks for the comments. That suggestion with the newspaper over the aircraft stripper is a great one.
I thought about making a removable receiver to hang my license plate there but the holes were already in the bumper from before so I took the easy road. That always gives me something else to fab and weld if I ever get bored.
Thanks for the comments, it was a long road but a very rewarding one now that I look back on it all. I'm really glad I took the time to post this build thread. Going back and seeing my own progress and everyone's encouraging comments made it all worth it. To think the first year of my build was in the first two pages.
The only things left I can think of is installing the rear seat belt, making a center console and installing my CB radio.
Mike
Coiz is offline
post #1808 of 1944 Old 03-21-2012, 10:08 PM
jeepcj7er
1983 CJ7
No problem. Any idea if your leak is from the windshield to cowl seal or from the fresh air box to cowl seal? The fresh air to cowl seal is probably the easier to fix.[/QUOTE]
Its from the windshield seal cause we ripped it and broke the windshield putting it in, its an easy fix cause this time we are hiring someone to put it in.
post #1809 of 1944 Old 03-21-2012, 10:11 PM
_Ross
I'm still here for another 21 days or so. Any help is always appreciated, big plan for the jeep in the future. There's a lot of body work to be done and the thing hasn't run in two years. We shall see what the PO set me up with... I really wanted to try my hand in brewing some beer. I already have a full size fridge converted into a kegerator, I figure its high time to put my own creation on tap.
_Ross is offline
post #1810 of 1944 Old 03-21-2012, 11:03 PM Thread Starter
Coiz
1979 CJ7
I can help with the beer and the Jeep.
Come home safe, I'll buy you a cold one! Maybe you can come out here for a brew day to see how I do it.
Thanks for serving our country.
Mike
Coiz is offline
post #1811 of 1944 Old 03-22-2012, 07:39 AM
_Ross
Sounds good
_Ross is offline
post #1812 of 1944 Old 03-22-2012, 03:11 PM
Jim1611
Jim1611's Avatar
Better put a snorkle on it Mike!! I happen to know a pond you can drive it through.
I think it'd look better with a nice big bull elk tied to the hood though.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #1813 of 1944 Old 03-27-2012, 05:26 PM
BomberJeep
2011 WK
Man 2 days and 121 pages later and I'm caught up. You have done some amazing work on this CJ. Kudos to you.
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #1814 of 1944 Old 04-01-2012, 05:48 PM
pbudzy
1982 CJ7
Awesome!
pbudzy is offline
post #1815 of 1944 Old 04-06-2012, 12:29 AM
2jeeps1stang
1987 YJ Wrangler
At a loss of words. Just spent 2 hours reading through this thread. I started doing homework for my project and this is where I ended up at. Unbelievable job. Always fun seeing a jeep n stang put together being partial to the two makes myself. Congrats on the finished product! I'm not too far over the boarder from you in IN. Looking forward to seeing what the future has in store! There's a big ford show in Mattson, IL every year. May 19th this year. All mustangs. You should cruise the jeep in there as I'm sure you would get a ton of exposure
Kyle
It used to be 2 jeeps..Now it's 4
http://www.jeepforum.com/forum/f22/red-yj-aka-elmo-1357728/
2jeeps1stang is offline
cj7 , frame , paint , welding
repairing rear frame on CJ7 (picture request) OlivergreenCJ7 Jeep CJ Forum 7 08-13-2009 08:43 AM
1979 Jeep CJ5 (just a picture, no tech.) mmerlina Jeep CJ Forum 20 05-15-2009 02:09 PM
1979 CJ7 Grille to Frame mount (Help) jpnkavu Jeep CJ Forum 3 10-15-2006 12:21 PM
1979 CJ5 Frame Up Restoration cyoungone Jeep CJ Forum 3 02-22-2003 08:30 PM
Frame off Resto. WarnRocker79 Jeep CJ Forum 4 03-12-2002 10:12 AM
