Coiz 1979 CJ7 Frame Off Resto; picture crazy - Page 113 - JeepForum.com
 3Likes
post #1681 of 1947 Old 10-17-2011, 10:06 AM
KNelson
1979 CJ7
Mike - congratulations for making it to the #3 google search result for "1979 CJ7" (beaten only by wikipedia and image results!!). I've spent countless hours going through your thread over the past several weeks - thank you for documenting as thoroughly as you've done. It looks great! My build is just starting (ugh) and I wanted to ask - Would you do anything differently if you had it to do again (such as dipping the frame, powdercoating, etc.)? Also, did you ever measure the underhood temps with the louvers open vs taped?
KNelson is offline
post #1682 of 1947 Old 10-17-2011, 11:28 AM
Renegade82
1982 CJ7
Originally Posted by Coiz View Post
Detroit EZ-locker ..... It is a little noisier than the one in the rear but it does not bother me.
Boy I took one out of my rear (well, not my... nevermind) because of the noise, I can't imagine one being even louder!
You missed a chance to POR those leafs when you had it apart, course it'll be easy to brush it on afterwards.
Renegade82 is offline
post #1683 of 1947 Old 10-17-2011, 01:36 PM Thread Starter
Coiz
1979 CJ7
Originally Posted by lucdog View Post
Mike, you do some great pictures, along with your work.
I have a stock pitman arm you can have. Ever get close to Peoria for work? We could meet. Or I could Snail mail it. PM your address, and I'll send it up.
Bill
Thanks Bill. I'll send you a PM about the pitman arm.
Originally Posted by Skerr View Post
Where's the pic with the new rubber!?!? Me wants...
Well, I had to get the spare tire carrier installed first. I also picked up a couple pairs of 13.5 thousand pound D-rings for the front and rear bumpers. They have the 7/8" pins and they are stout! BESRK does such a great job on his bumpers and tire carriers.
Originally Posted by jeepsterjc View Post
That went together really nice. I wonder how long those new MTs will hold their tread?? I mean... your gas pedal is digital, right... 0,1... up or down, right??
Ha, I am working on finding the middle range and not just the on/off.
#3 on Google huh? Sweet. Thanks for taking the time to read through the thread. To answer your question on what I might do different, I probably would consider acid dipping the frame and maybe even a galvanize dip. I'd also make sure I was completely done welding on the frame before I applied the paint. It killed me to grind off a nice coat of paint to weld on my roll bar tie-ins and rear crossmember reinforcement then having to go back and touch them up.
I haven't done the louver temperature test yet. It would probably be best to do in the heat of the summer but maybe I'll give it a shot toward the end of this week.
Those lunchbox lockers can be noisy but once you learn how to drive with them they aren't too bad.
When I was originally bead blasting everything, I had planned to separate the spring packs to clean and paint each spring individually but a group of guys at the dealer talked me out of it. So I just cleaned and painted the POR on the outsides of the spring packs. Now you can obviously see the rust bleeding through from the center of the spring packs. The close up photos with the flash makes it look worse than it actually is. I'm not sure if I will ever take the time to do that. Until then I'll probably just touch them up with some Rustoleum black.
Mike
Coiz is offline
post #1684 of 1947 Old 10-17-2011, 05:59 PM Thread Starter
Coiz
1979 CJ7
I've got a bunch of new pictures to upload sometime tonight but this should get you started. I stopped and took this single shot because I thought I was going to lose the sunlight on my way to where I wanted to take the pictures and I did. This is the only one that shows the pop of the HP White. The white has orange and yellow tints to make it stand out in sunlight.
Mike
Coiz is offline
post #1685 of 1947 Old 10-17-2011, 06:03 PM
Rollbar
1984 CJ8
Sweet, is it for sale
I know, to much work.
J/K
<----Click
<---- Click
Rollbar is offline
post #1686 of 1947 Old 10-17-2011, 06:04 PM
boomvader
Bravo, Mike!! Very, VERY nice!!!! :-)
-boom
Boom's CJ-7 Project (Completed in 2011)
boomvader is offline
post #1687 of 1947 Old 10-17-2011, 06:17 PM
CJ7ROB
Looks awesome Mike, love the COBRA J7 plate.
CJ7ROB is offline
post #1688 of 1947 Old 10-17-2011, 06:22 PM
Skerr
WOW!! Just wow...
Kerrdog
Go Fish! <*////><
Skerr is online now
post #1689 of 1947 Old 10-17-2011, 08:10 PM Thread Starter
Coiz
1979 CJ7
Here are a few more. You can see the sun went behind the clouds.
Just noticed I forgot to put my AMC Jeep emblem on.
Mike
Coiz is offline
post #1690 of 1947 Old 10-17-2011, 08:12 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
That's the nicest CobraJ I've ever seen. Nicer than my project will likely turn out!! Wow.
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #1691 of 1947 Old 10-17-2011, 08:27 PM
jakeryii
1967 CJ5
That... is... GORGEOUS!!!!!!!!!
94 ZJ 4.0, np 249 on 31x10.50s no lift
jakeryii is offline
post #1692 of 1947 Old 10-18-2011, 08:56 AM
tractor1
1979 CJ5
Mike look like it came off the showroom floor
( you need to do something about the license plate
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4 lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
tractor1 is offline
post #1693 of 1947 Old 10-18-2011, 09:10 AM
boomvader
Mike, do the D-rings rattle at all? Where did you pick those up?
You did an awesome job from start to finish on this project. AAA+++
-boom
post #1694 of 1947 Old 10-18-2011, 09:19 AM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
You mean you're finished?
I think the engine is dripping- yeah- right there. You may need to pull the front clip, drop the axle, remover the seats, lube the sliders and open that 5.0 up for an inspection!
post #1695 of 1947 Old 10-18-2011, 09:20 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Mike,
I haven't begun to digest the feast of information in this thread. My only regret is I didn't tune in earlier!!
Your fabrication, documentation, attention to detail, and ability to follow a concept thru to completion has been a pleasure to read and learn from.
I hope you take that beauty out and enjoy it, because you sir have earned it.
Matt
Matt1981CJ7 is offline
cj7 , frame , paint , welding
repairing rear frame on CJ7 (picture request) OlivergreenCJ7 Jeep CJ Forum 7 08-13-2009 08:43 AM
1979 Jeep CJ5 (just a picture, no tech.) mmerlina Jeep CJ Forum 20 05-15-2009 02:09 PM
1979 CJ7 Grille to Frame mount (Help) jpnkavu Jeep CJ Forum 3 10-15-2006 12:21 PM
1979 CJ5 Frame Up Restoration cyoungone Jeep CJ Forum 3 02-22-2003 08:30 PM
Frame off Resto. WarnRocker79 Jeep CJ Forum 4 03-12-2002 10:12 AM
