Coiz 1979 CJ7 Frame Off Resto; picture crazy - Page 106 - JeepForum.com
 2Likes
post #1576 of 1947 Old 07-11-2011, 06:45 AM
hallsofstone
This will always be one of the best and most interesting/detailed builds on JF. One of my personal favorites!
Jeeping Ohio Every Day
00 TJ Sport - Ever evolving DD/Rig
85 Suzuki GS700 - ugly
K.C.C.O.
hallsofstone is offline
post #1577 of 1947 Old 07-11-2011, 07:11 AM
MoC
Mike,
Just did a little catching up!
MoC is offline
post #1578 of 1947 Old 07-11-2011, 11:56 AM
SaskCJ7
1982 CJ7
Coiz, I have read your build thread start to finish and am truly inspired by the remarkable level of craftsmanship you have demonstrated on your jeep. I live in a place where for the most part the philosophy is "who cares what the truck looks like, just throw some expensive wheels and a 3000$ stereo in it and you're golden". I am currently rebuilding my own 82 CJ7, and you can be sure your build thread is gonna be a MAJOR source of information. Yours is one of the nicest Jeeps I've seen, and a tribute to the patience and discipline you put into it. Hope mine turns out half as nice. Cheers!
SaskCJ7 is offline
post #1579 of 1947 Old 07-23-2011, 10:04 AM
Jim1611
Jim1611's Avatar
Hey Mike have you installed the front bumper yet?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #1580 of 1947 Old 07-24-2011, 12:43 PM Thread Starter
Coiz
1979 CJ7
Thank you, I appreciate the response.
Thank you as well. It has been a lot of work and all that time and effort has definitely paid off in the end.
Hi Jim, I did get the bumper and winch installed and that sucker is stout. One thing I did before installing the winch was I took the cover off the relay box to upgrade the factory heat shrink on the terminal ends. I was also just curious to see what the relay looked like.
Here it is with the relay cover removed. I was considering upgrading the wiring size but figured I would just run these for now. That might be something I do in the future.
You can see the cheap factory heat shrink still on the red wire and the heavy walled adhesive lined heat shrink on the black.
While I was at it I used MAP gas to heat up the terminals and add silver bearing solder to the crimps. Here are most of the lines completed. I did this to every terminal end.
I didn't really take step by step pictures but I basically bolted the winch to the mounting plate then set it in place. Next I slid the bumper into the frame rail ends and aligned all of the bolt holes. I got all of the bolts started by hand then installed the roller fairlead before I cranked everything down tight.
Here are the bolts on the driver's side rail. The far left bolt is for the bumper tab where it goes through the frame rail and threads into the clevis mount. The first winch mounting bolt also goes through the frame and threads into the clevis mount. The bolt on the far right has a crush sleeve in the frame rail and threads into the heavy duty steering box mount. The bolt that comes down from the top also ties the winch mount plate, bumper and frame together.
The passenger's side gets the same basic treatment. The smallest bolts on the entire setup are the four bolts that secure the actual winch to the mounting plate.
After that I installed the relay box onto the winch.
Hooked up the wires. Everything looks nice and clean. I plugged in the controller and powered it forward and back about an inch to make sure it works. Now I just need to get some D rings for my clevis mounts so I can install the hook on the cable and have somewhere to clip it to.
Mike
Coiz is offline
post #1581 of 1947 Old 07-24-2011, 12:50 PM Thread Starter
Coiz
1979 CJ7
Here are a couple shots of it out of the garage. Not the best lighting as it was late in the day and starting to get dark.
Mike
Coiz is offline
post #1582 of 1947 Old 07-24-2011, 02:12 PM
mvigo
mvigo's Avatar
that looks complete!! Nice job!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is online now
post #1583 of 1947 Old 07-24-2011, 04:43 PM Thread Starter
Coiz
1979 CJ7
Thanks Mike.
It is not quite complete but it is very close. I am looking for a spare wheel to match what I have and think I am just going to repaint them black to match the frame and bumpers. I'm still trying to decide between the KM2's or the MT/R's.
Mike
Coiz is offline
post #1584 of 1947 Old 07-24-2011, 04:59 PM
Jim1611
Jim1611's Avatar
Looks to me like you're ready to get that thing dirty Mike.
Hey when you put new heat shrink on the wires are they now water tight? Your bumper looks good all mounted up too. You're almost done my friend.
Both of those look like great tires Mike. Hard choice but I lean towards the KM2s. You going bigger on them than you have?
My build thread
Jim1611 is offline
post #1585 of 1947 Old 07-24-2011, 05:58 PM
johnsom5
I agree with the km2's. Got them myself. And even though my cj is no where near the quality of yours, I still get crap from the guys for not getting her dirty. It's starting to gain more mall crawler status each time I take it on the roads and to the beach.
johnsom5 is offline
post #1586 of 1947 Old 07-24-2011, 09:36 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I bought 5 MT/Rs with Kevlar and have a year to go before they roll for real under the CJ. I've read that they are a quiet rolling tire but also have great traction... I hope to hear back from someone about an actual experience with them rather from someone with a vendor supplied set.
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #1587 of 1947 Old 07-24-2011, 10:12 PM
twinstickd20
1979 CJ7
Be prepared to be spoiled with them, once you run them you will love them. They are quieter than most all terrains but yet very good off road.
My Build Thread
twinstickd20 is offline
post #1588 of 1947 Old 07-24-2011, 11:55 PM
mvigo
mvigo's Avatar
I think you are splitting hairs between the KM2's, MT/R's and the Cooper Discoverer STT's...I love the looks of the KM2's the best but ended up with the STT's because they are made in the USA...performance wise, they have handled everything I have dished out to them...
mvigo is online now
post #1589 of 1947 Old 07-25-2011, 04:22 AM
JnH_78CJ7
1979 CJ7
The MT/R's with Kevlar is your best bet for all around performance. Very quiet on road and a monster off road. With it's added side wall reinforcement, it can be aired down pretty low with decent stability. You will be very happy with these tires.
"When i die bury me in my jeep because it has never been in a hole it couldnt get out of!"
JnH_78CJ7 is offline
post #1590 of 1947 Old 07-25-2011, 09:47 PM Thread Starter
Coiz
1979 CJ7
Yes Jim, the adhesive lined heat shrink does make them water proof connections.
I had originally added the extra 1.5" of lift and cut my rear fenders for the 35's but now that it is done, I think I'm going to stick with the 33's. I like the stance and don't want to sacrifice any more performance in acceleration and braking due to the added weight of the 35's. The 1" I would gain in ride height would be minimal and not worth the trade off considering it will be more on road than off for a while.
At least you have a CJ and you're out enjoying it.
That's why I have been torn between the two. I saw a convoy of military vehicles on trailers stopped at a rest stop recently and everyone of them had brand new MT/R's installed. They looked mean with the center all-terrain section and the big beefy lugged outer tread. I figured if they used them in the military they probably tested pretty good.
The KM2's seem to get a little better feedback and ratings across the board on the internet. Mainly in that they are quieter on the street and they wear better/longer.
Mike
Coiz is offline
cj7 , frame , paint , welding
repairing rear frame on CJ7 (picture request) OlivergreenCJ7 Jeep CJ Forum 7 08-13-2009 08:43 AM
1979 Jeep CJ5 (just a picture, no tech.) mmerlina Jeep CJ Forum 20 05-15-2009 02:09 PM
1979 CJ7 Grille to Frame mount (Help) jpnkavu Jeep CJ Forum 3 10-15-2006 12:21 PM
1979 CJ5 Frame Up Restoration cyoungone Jeep CJ Forum 3 02-22-2003 08:30 PM
Frame off Resto. WarnRocker79 Jeep CJ Forum 4 03-12-2002 10:12 AM
