Clutch won't disengage after replacement - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Clutch won't disengage after replacement
Unread 02-11-2013, 10:59 AM   #16
Renegade578
1981 CJ7
Originally Posted by S76 View Post
Just now saw the bushing pic.
Do you think that pilot shaft bushing could have goten gotten a little mushroomed on the install making it tight on the shaft?
That would keep the input spinning and act like the clutch was not disengaging.
Edit--Does the plastic clutch installer tool still fit the crank bushing well?
Hindsight.......20/20
When you first had the prob. You could have tried to start it in gear with the clutch in. If it's the bushing draging it would have started. If it's truley the clutch not disengaging the Jeep would move on the starter.
That was one thing I forgot to mention. I had a really hard time getting the new pilot bushing in. There was a small bur on the inside of the crank shaft that I tried to sand down. I froze the bushing before installing and even heated up the crank, but the bur was making it very difficult to get the bushing in straight. I eventually was able to get it started straight, but as you can see from the picture it took excessive force. I know the new bushing fit the input shaft before installation, but once the new bushing was installed the clutch alignment tool did not fit. I had a feeling something wasn't right at this point, but continued anyway. All signs are pointing to this being the source of my problem.
Renegade578 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 11:26 AM   #17
keith460
Jeep. There's Only One
keith460's Avatar
I see the damage on the pilot bushing as well and would definitely suspect that is the cause of your problems. Heating the crankshaft and freezing the bushing is a good thing but oilite bushings should be installed with a soft piece of aluminum or wood dowel rod and nothing harder. Don't forget to installed an oil soaked piece of foam inside the crankshaft to lubricate the bushing for at least the next 100,000 miles.... the factory does.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 11:35 AM   #18
Fireblade
1983 CJ7
I had the same problem and it was the pilot bushing, in my case it was just because a friend of mine machined it and we don't let enough gap !
Fireblade is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 11:50 AM   #19
S76
I never knew that. Thanks for the tip.
Bob
S76 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 12:32 PM   #20
MoC
Do you do that on the self lubricating ones as well Keith?
MoC is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 12:46 PM   #21
keith460
keith460's Avatar
Self lubricating meaning what? Oilite? Yes.
Oilite bushings excrete small amounts of oil when temperature rises from friction. It must be replenished with oil that gets spent. When the bushings cool down, it absorbs the oil but it has to come from somewhere.
1984 CJ-7 Renegade
Unread 02-11-2013, 12:57 PM   #22
MoC
Oilite must be the term. The last 2 I did that were self lubricating said not to put additional oil on them. Guess it can't hurt, was just wondering.
Unread 02-11-2013, 01:08 PM   #23
keith460
keith460's Avatar
Here's an excerpt from the Jeep Factory Service manual:
1984 CJ-7 Renegade
Unread 02-11-2013, 02:32 PM   #24
MoC
Tried to find the install instructions on the last clutch I did but came up empty. Positive the last 3 I put in said not to lubricate them, but I am sure it cant hurt. Were the OEM ones Olite? If not maybe thats why the FSM says to install a wick.
Unread 02-11-2013, 03:00 PM   #25
82JeepCJ7
1982 CJ7
I've always soaked my pilot bushing in 5w motor oil for about a week prior to installing. The material is porous and soaks up oil like a sponge.
Rather than removing the bushing, try to carefully flap the inside out of any burrs etc.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 03:57 PM   #26
Renegade578
1981 CJ7
What do you mean by "flap"?
Unread 02-11-2013, 04:39 PM   #27
keith460
keith460's Avatar
You are better of using a reamer or a drill bit that fits the ID of the bushing. Do it by hand if you can using oil for lubricant.
1984 CJ-7 Renegade
Unread 02-11-2013, 04:53 PM   #28
cj5huntingrig
1974 CJ5
Do yourself a favor and replace the bushing. They are cheap. You should not have to use much force to get it in. Your old one is toast.
When you pulled the trans back off, did it come apart easily or did you really have to work at it?
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 04:56 PM   #29
Renegade578
1981 CJ7
Definitely had to work at it. Took about 2 hours.....
Unread 02-11-2013, 05:14 PM   #30
jblue1555
1979 CJ7
When you installed it did you have to pull it in with the bolts?
jblue1555 is offline   Reply With Quote Quick reply to this message
