Clutch won't disengage after replacement - Page 3 - JeepForum.com
post #31 of 38 Old 02-11-2013, 04:26 PM Thread Starter
Renegade578
1981 CJ7
Originally Posted by jblue1555 View Post
When you installed it did you have to pull it in with the bolts?
Against my better judgement, yes I had read not to do it, but did it anyway out of frustration. I justified it with myself at the time by saying I didn't have to crank very hard on the bolts....
Renegade578 is offline
post #32 of 38 Old 02-11-2013, 04:35 PM
cj5huntingrig
1974 CJ5
You were probably just compressing everything inside the case and stretching your bell housing. I doubt your pilot shaft even when into the bushing. Definitely do not reuse the old bushing. I would say with some certainty that you damaged the bushing beyond repair. Also if you got omix parts there's a good possibility that they sent you the wrong bushing or the on that they sent you was a piece of junk. Check and double check your part number before your re order a new bushing. Im sure some of the guys on here could give you a good quality part number.
I know NAPA offers a pilot bearing (BRG B041) I have not checked the application though. Some will tell you to stick with the bushing (BRG B656). The funny thing is, even NAPA doesn't list the application online (even though your year and model was selected) and the bearing and bushing have different inner and out diameters
Good luck. Evan
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #33 of 38 Old 02-11-2013, 07:41 PM
82JeepCJ7
1982 CJ7
Originally Posted by Renegade578 View Post
What do you mean by "flap"?
Using a small diameter flapper wheel on a die grinder. I touched mine up after I drove the bushing in. Just made sure there wasn't any burs etc.
Did the clutch alignment tool fit into the bushing?
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #34 of 38 Old 02-11-2013, 08:22 PM
muddigger95
Replace e bushing they are cheap. Before you put it back in try to get that bur out of there even if it takes a will its worth it. Reinstall the new one. If it does it again push it out of the shop and on a straight away start it in gear and rev it up while in gear and let up , do this a few time and it should break loose. Chances are this time it will be just fine. Good luck. Things like that are frustrating.
muddigger95 is offline
post #35 of 38 Old 02-11-2013, 09:12 PM
82JeepCJ7
1982 CJ7
As my Dad says "It will wear in"
post #36 of 38 Old 02-12-2013, 11:52 AM
Noplainsdrifter
1974 CJ5
When you get your new bushing, make sure it fits your transmission shaft BEFORE you install it in the crank.
It's a Jeep Thing, Chrysler Doesn't Understand!
Noplainsdrifter is offline
post #37 of 38 Old 03-02-2013, 06:24 PM
84jeepjohn
I'm gonna jump in on this too!!!! Sorry if I'm hi jacking the thread !!!!!
I just did the SAME stuff the op did.... And I too am having the same issues.
I too had a bear of a time getting the trams back in too.
Unfortunately once I got the pilot bushing in the crank the tool would not fit.
Granted I beat on her and got it all back together.... Guess I shouldn't have done that
So if the input shaft on the trans is stuck in the pilot bushing what would the symptoms be?
I was able to adjust the linkage enough to JUST get it to move slightly. Right now I have NO free play in the clutch peddle either.
84 CJ-7 RE 4.5" lift TJ flares and 35"BFG's
4.88's and OX lockers front and rear
2000 Grand Cherokee, 2" lift, BFG AT's (SOLD)
2005 Z71 Suburban with 1.5" rear spacers, and front leveled
84jeepjohn is offline
post #38 of 38 Old 03-03-2013, 09:30 AM
84jeepjohn
Well I'm gonna tear mine back apart. Question on the pilot bushing. If I go in with Emory cloth and can open it JUST enough to get an alignment tool in there will that be ok?
I'm gonna get a caliper and see what the size difference is between the trans input shaft and the inner diameter of the bushing are today
I honestly think I may have the clutch disk in backwards too.... This was supposed to be a do it in a day or two job and with family and work it's been like two weeks.
FYI I looked and my disk did NOT sat anything about the orientation.
