Clutch will not engage in cold weather - JeepForum.com
post #1 of 6 Old 12-08-2008, 05:40 AM Thread Starter
redcj7
I have a 1985 cj7 4cyl with hyd. clutch and during the cold it will not engage. Is this an easy/cheap fix?
redcj7 is offline
post #2 of 6 Old 12-08-2008, 08:11 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I would drain out the fluid and put some fresh fluid in there. Sounds like yours may be contaminated with water.
Try opening the bleeder and see if it moves all the way back and that it's not some other mechanical problem
John Strenk is offline
post #3 of 6 Old 12-08-2008, 02:19 PM Thread Starter
redcj7
Thanks I'll try
redcj7 is offline
post #4 of 6 Old 12-08-2008, 03:40 PM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Check to make sure you are using the correct fluid too !
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #5 of 6 Old 05-20-2009, 08:39 AM
KisDozerK3
had the same problem...you need to replace the Clutch master & slave cylinders. should fix it
KisDozerK3 is offline
post #6 of 6 Old 05-20-2009, 09:50 AM
iagmc
1974 CJ5
MAKE SURE YOU USE CORRECT FLUID. There are two type. that old should use a DOT3, new clutches can use DOT4 which are not the same. DOT3 will eat the seals on 4 and you will need to replace everything.
Most people don't see the light till they feel the heat.
iagmc is offline
Cold Weather Stall. hagan39 Jeep CJ Forum 10 10-29-2009 05:09 PM
Cold weather oil in L-134 PaulS Jeep CJ Forum 1 12-21-2008 09:24 PM
cold weather, stuck in gear awalp Jeep CJ Forum 10 12-19-2007 11:44 AM
Clutch won't engage ANJEEP69 Jeep CJ Forum 1 11-06-2005 05:47 PM
Cold/ Wet Weather Starting Problem paypwip Jeep CJ Forum 2 03-06-2003 08:15 AM
