Clutch Troubles? Help! - JeepForum.com
post #1 of 2 Old 10-07-2003, 12:45 AM Thread Starter
prthead79
I have a 79 cj 5 with a 360 that i just finished building and installed. Problem is the clutch(i think) isn't working right. i put a new pressure plate in when i put the motor in. now when i drive it about 100 miles it gets hard to get it in gear at stops, any gear. i adjusted the clutch out and that fixed it for about 100 more miles then the same thing happened. now i have it out so far that when i nail it the clutch slips. i know that the clutch was designed to slip on the jeeps but this is in excess. i can't figure out what is causing the problem and i know for a fact that the adjustments aren't moving. this is not a hydraulic clutch by the way. can anyone help? the pressure plate i put in was not the diaphragm like the original, could this be the problem? i am lost!
prthead79 is offline
post #2 of 2 Old 10-07-2003, 05:47 AM
KG4PAM
The pivot ball may have come out of its socket. I had the problem you are describing, and found out that the ball was missing. this makes the clutch fork not have anything to rest on, it requires more travel than the adjustments allow. feel around through the fork boot, see if you can find the pivot. it it's gone, most lkely that is what has been your problem. You may need to pull the tranny and glue another in place(pivot ball, not tranny...), or with enough finesse you may be able to replace it through the fork boot. good luck!
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
Hot Jeep... clutch troubles? Car show Parade... soccerpapa Jeep CJ Forum 10 07-14-2008 03:39 AM
SR4 Troubles kjhibbs Jeep CJ Forum 11 05-07-2008 08:25 AM
CJ5 troubles... Jmila1901 Jeep CJ Forum 9 07-26-2007 11:05 AM
T-150 Troubles Jeepfolk Jeep CJ Forum 4 07-08-2007 08:26 AM
tow bar troubles stevenbaty Jeep CJ Forum 6 05-21-2006 06:45 PM
