Clutch smoking...adjustment needed? - JeepForum.com
post #1 of 5 Old 09-08-2011, 05:47 AM Thread Starter
itsybitsy
1977 CJ5
Went off roading for the first time with my '77 CJ5 T-150 this past weekend. I was in a few very precarious spots where I had to abuse the clutch. Abused it to the point it was smoking at one point trying to get out.
Afterwards I noticed that the clutch does not engage until almost realeased all the way out. Where as before it was about 3/4 up. My question is can this be corrected with a simple adjustment or did I burn out my clutch/pressure plate?
Thanks for the advise -
itsybitsy is offline
post #2 of 5 Old 09-08-2011, 06:15 AM
bkeese
1949 CJ3A
Yes and probably!
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #3 of 5 Old 09-08-2011, 06:48 AM Thread Starter
itsybitsy
1977 CJ5
Yes, it may be fixed with a minor adjustment?
post #4 of 5 Old 09-08-2011, 08:35 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I would try and adjust it first,
Then put it in 3rd release the clutch and see if the engine revs without moving the jeep. Then you need a replacement.
Reminds me when I was a young punk in my 69 Mach 1 and was doing a little roll back on a burn out but I put it in 3rd instead of 1st. A lot of smoke poured out from under the car but it wasn't the tires, It was the clutch. And a burning clutch smells a lot worse than burning rubber. I barely had enough clutch left to drive it home.
John Strenk is offline
post #5 of 5 Old 09-08-2011, 09:09 AM
Noplainsdrifter
1974 CJ5
Next time....
USE LOW RANGE!
It's a Jeep Thing, Chrysler Doesn't Understand!
Noplainsdrifter is offline
Clutch adjustment kstopp Jeep CJ Forum 1 05-18-2008 07:04 AM
Clutch adjustment jrylb73 Jeep CJ Forum 1 03-15-2007 12:19 AM
HELP! T-176 clutch adjustment cj5one Jeep CJ Forum 3 03-09-2007 01:00 PM
New Clutch smoking calcallender Jeep CJ Forum 13 09-02-2006 08:06 PM
cj7 clutch adjustment? 1bflm Jeep CJ Forum 2 07-21-2006 09:13 PM
