clutch slave cylinders - JeepForum.com
post #1 of 8 Old 01-30-2011, 03:36 PM Thread Starter
Bakunin
Bakunin's Avatar
argh!
I have to replace my slave cylinder. I am not sure which year/model the kit I installed years ago used. The one I pulled out says "Girling made in UK" and the # 74660580 q5 on it.
As you can see, I bought the one for the '85 CJ and here is the difference in bolt patterns. Anyone know off the top of your head which cylinder I should ask for at the parts store?
Bakunin is offline
post #2 of 8 Old 01-30-2011, 05:51 PM Thread Starter
Bakunin
Bakunin's Avatar
OK I figured it out. My '85 CJ7 258 had the '90 Wrangler clutch master cylinder and the '81 CJ7 clutch slave cylinder.
These are the parts in the kit which replaced my old mechanical clutch linkage.
Bakunin is offline
post #3 of 8 Old 01-18-2013, 02:47 PM
Jeep-Power
Thanks for this thread!
I am having the same issue. It seems the model on the right was used on '81 151 4 cylinder CJ's.
The Napa Part Number is 73173
Autozone part #: 11956
PS-- I am borrowing your photo for my build thread. I hope that is OK.
--TallPeter
'08 JKU Rubi ~ her DD
'84 CJ-7 ~ Tonned & Turbo'd
'62 CJ-5 ~ Stocker
Jeep-Power is offline
post #4 of 8 Old 01-18-2013, 03:21 PM Thread Starter
Bakunin
Bakunin's Avatar
Yep
Have at it!
Bakunin is offline
post #5 of 8 Old 01-18-2013, 04:28 PM
caseypotts
1980 CJ7
I sure have gone through several of them. How long has yours lasted? Mine start to leak pretty quickly and I end up replacing the fuild every week or so until I break down and buy or rebuild.
I'm sure it has something to do with the fact that the PO removed the heat sheild so it get pretty hot being cooked over the exhaust but I have had no luck in finding a replacement sheild.
1980 CJ7 GM151 Bored out, Flat Top Pistons, Hedman Header, 2.5in Superlift springs, Extrem Shocks' 31 10.5 Mastercraft Courser MT tires on Allied MockLoc rims, Blazer heater upgrade.
Her Ride
2003 Liberty Renegade
caseypotts is offline
post #6 of 8 Old 01-18-2013, 05:31 PM
jeepster4245
1982 CJ5
Caseypotts; Trust me it isnt something the PO did...The clutch master cylinders are one of the regularly replaced items on the cjs...I replaced mine 3 times this year and on the third one I seemed to have got lucky..good luck
jeepster4245 is offline
post #7 of 8 Old 01-18-2013, 06:37 PM
yellow85cj
The one on the left is for an AMC 4 cyl. 150 used in 84/85/86 years. Only works on the AMC 4 cyl.
Currently in pieces - all of them
yellow85cj is offline
post #8 of 8 Old 01-18-2013, 07:39 PM
caseypotts
1980 CJ7
I would agree with you Jeepster but I gotta think that the heat shield would help protect it. Maybe allow them to last longer???? I hope I'm lucky one of these times as well, I think this will be #4 for me plus a couple rebuilds.
Her Ride
86 CJ clutch slave bleeding jshi218 Jeep CJ Forum 8 10-15-2012 11:15 AM
clutch master cylinders twoleos617 Jeep CJ Forum 2 11-20-2009 08:07 AM
86 CJ7 Clutch Slave Cylinder, HELP!!! joemac421 Jeep CJ Forum 7 08-13-2009 12:15 PM
Clutch Slave Cylinder- Which one??? xcopy Jeep CJ Forum 6 12-03-2004 01:40 PM
clutch master and slave uglydoug Jeep CJ Forum 3 11-01-2003 12:44 PM
