Clutch Slave Cylinder Fitting... - JeepForum.com
post #1 of 2 Old 01-18-2010, 03:18 PM Thread Starter
poppatello
Is there a trick to remove the hydraulic line from the clutch slave cylinder? I messed up the fitting and now can not get a wrench on it. I can't get a vise grip on it either. I am thinking of just cutting the line in half and replacing it. Can I get a replacement line or will I have to make one???
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 2 Old 01-18-2010, 04:58 PM
rishar1
1973 CJ5
you can get replacements that are pre bent or you can get braided lines which flex or you can buy a piece of straight brake line from autozone or wherever and bend it yourself they all have the fittings already on them
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
86 CJ7 Clutch Slave Cylinder, HELP!!! joemac421 Jeep CJ Forum 7 08-13-2009 01:15 PM
Clutch Slave Cylinder Not Extending hellswraith Jeep CJ Forum 3 06-17-2009 12:05 PM
258 clutch slave cylinder issues AMC Power Jeep CJ Forum 17 07-13-2007 07:13 AM
Clutch Slave Cylinder issue itsjustme0770 Jeep CJ Forum 3 05-16-2006 08:11 AM
Clutch Slave Cylinder- Which one??? xcopy Jeep CJ Forum 6 12-03-2004 02:40 PM
