Clutch rod - JeepForum.com
post #1 of 6 Old 06-24-2002, 06:06 AM Thread Starter
TUFFGRL
1976 CJ5
Talking Clutch rod
When I got my Jeep it had a homemade 3" body lift. It also had a homemade extension on the clutch rod. Yesterday it snapped. Can I buy a clutch rod the length I need and maybe adjustable or do I have to have this fabricated? Body lifts seem to be more of a pain than they are worth. If I had the money now I would go to all suspension lift and eliminate all these rigged extensions!! Any thoughts?
TUFFGRL is offline
post #2 of 6 Old 06-24-2002, 06:23 AM Thread Starter
TUFFGRL
1976 CJ5
Post
Just a little update. What I really need is the piece from the firewall to the first pivot. Also kudos to the husband for coming to save me. He managed to clamp the two pieces together long enough to get into second and drove all the way home without stopping!! This included several slow approaches waiting for lights to turn green and one trip off road when an ambulance was coming!! I hope someone has an easy answer for me. I think he is getting tired of working on my toy all the time!!
TUFFGRL is offline
post #3 of 6 Old 06-24-2002, 08:51 AM
NC74CJ
NC74CJ's Avatar
Post
i would get the extension welded to the rod to avoid problems....
A stroke bolder, a pinch better.
NC74CJ is offline
post #4 of 6 Old 06-24-2002, 08:56 AM Thread Starter
TUFFGRL
1976 CJ5
Post
I need a new/another rod. The method of extension the previous owner used has totaled this one. Are you saying I have to find a stock piece and have an extension added? I was hoping that they would sell longer or adjustable versions knowing people with body lifts will need them!!
TUFFGRL is offline
post #5 of 6 Old 06-24-2002, 09:41 AM
Infedel
Post
Go buy a new clutch rod from either 4WD Hardware, Quadratec or Rosser. Cut the rod about 2" above the lower pivot point. Use 2 pieces of 1" angle iron to reattach the clutch rod pieces back together, spacing them appart as appropriate for you're bodylift. I have a 1" bodylift and this is what i've done, with no problems. There should be a local welding shop that can do the welding and cutting for you if you do not have the tools. Here's a picture of my clutch rod:
<img src="http://www.members.tripod.com/jeepitup/2c7c8960.jpg" alt="" />
If you would like a higher resolution picture, email me and I will send it to you.
'84 CJ-7
AMC 258 Stroker
Centerforce II Clutch
1" Body Lift
1" Shackle Lift
33x12.5" SSR Tires
Painless Wiring, Stainless Steel Dash
Infedel is offline
post #6 of 6 Old 06-25-2002, 06:57 AM Thread Starter
TUFFGRL
1976 CJ5
Cool
Thanks for the help everybody!! My husband went to George's 4wheel parts and service yesterday. George fixed me right up on the spot. They cut the good top portion off my rod and a good bottom portion off one he had with a little extra length. He dropped what he was doing and welded it up right then. He reinforced the little nubs on the end that were worn. He is awesome. He only charged me $25, which I think is great. Anyone in the northeast part of Cincinnati should look George up. He loves Jeeps and seems to really know his stuff.
TUFFGRL is offline
hydraulic clutch - clutch won't disengage kercher Jeep CJ Forum 13 10-24-2009 11:27 AM
t150 clutch/t15a need correct clutch kit? speediemb Jeep CJ Forum 1 02-05-2009 09:52 PM
Which Clutch? Fropleyqk Jeep CJ Forum 10 05-02-2007 05:21 PM
Clutch works but I hear a whirring when I press the clutch pedal to the floor? part.changer Jeep CJ Forum 12 04-10-2007 02:31 PM
Clutch sdcannon Jeep CJ Forum 1 09-13-2006 04:16 AM
