@^@%!%& clutch release arm pivot ball - JeepForum.com
post #1 of 41 Old 09-06-2011, 05:44 PM Thread Starter
bamajeep83
1979 CJ5
While adjusting the clutch linkage the clutch arm pivot ball fell into the clutch housing. This may be a stupid question but if I cannot get the ball out without pulling the transmission, would it hurt anything to leave it in there? It seems it would be behind the clutch and the flywheel. I know it is a risk but how big of one?
bamajeep83 is offline
post #2 of 41 Old 09-06-2011, 05:49 PM
BrandonJames
1974 CJ5
I'd take it out.
BrandonJames is offline
post #3 of 41 Old 09-06-2011, 06:03 PM
mopar346
It would become a projectial, it has to come out. Try a magnet through the fork opening and it that is not successful, take the bolts out of the inspection cover to flex it out to gain a little access that way. Either way it has to come out.
Careful your character's showing
mopar346 is offline
post #4 of 41 Old 09-06-2011, 06:04 PM
stodg73
1979 CJ5
I would take it out, because you may not know what kind of damage it will cause.
'79 CJ5, 258 c.i., Carter BBD, T-150, Dana 20, Dana 30, AMC 20, 33x12.50x15, 3" body lift, taking it back to stock, then tearing it apart and putting it back together again!
stodg73 is offline
post #5 of 41 Old 09-06-2011, 06:18 PM
only in a jeep cj
Plus, the fork pivoting on the aluminum tower that held the ball will not only destroy that, but the fork will be sloppy and the throughout length will be off. I bet your inner return spring is missing or stretched out and allowed the ball to fall out.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #6 of 41 Old 09-06-2011, 06:55 PM
countryman247
1979 CJ7
I had the same thing happened to me. I had to slide the trans back to get it out. I am currently not using the ball because I forgot to reinstall it from changing out the throw out bearing. Don't forget to put it back in it sucks bad everything is sloppy the clutch don't disengage all the way. The pedal has tons of slop I can continue but I think you get the idea
countryman247 is offline
post #7 of 41 Old 09-06-2011, 10:09 PM
ejeeperguy
1982 CJ7
I just want to use the word bullet.It is about the size of a deer ball round .You get that going inside and bye bye clutch, bell housing, and anything else it wants to come in contact with.
Now the good news pop the starter off. Feel inside you might just get lucky with finding it there.
ejeeperguy is offline
post #8 of 41 Old 09-07-2011, 05:36 AM Thread Starter
bamajeep83
1979 CJ5
Thanks for the advice. I had not thought about taking the starter off. Good suggestion.
post #9 of 41 Old 09-07-2011, 09:23 AM
mopar346
Great thought on the starter, it didn't cross my mind either.
mopar346 is offline
post #10 of 41 Old 09-07-2011, 10:06 AM
ejeeperguy
1982 CJ7
Your welcome,
What are Jeep friends for.
Happy Wheeling!!
post #11 of 41 Old 09-07-2011, 10:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
And if you do have to move your tranny, just put in some long studs in place of the bolts so you can slide the tranny in and out easily. At least enough room to replace the spring and install the pivot ball.
John Strenk is offline
post #12 of 41 Old 11-27-2012, 07:43 PM
MMA_Referee
I realize this thread is older but I have something to add. I too replaced my clutch and tranny only to find my pivot ball fell out too. I used an extendable magnet through the fork opening and retrieved the ball. Then I made a tool out of a coat hanger to reinsert the ball without removing the tranny.
I attached 2 pics to show materials and how the tool was used.
I did all this through the fork opening and worked around the exhaust as well. I used a slotted screwdriver to hold fork away since the inside spring worked against me. This created enough room to insert the ball. But, once the ball is in there, I did not want to pull it back out so I wrapped tape close to the bottom before inserting so I could cut it with a razor blade and let it spring apart and away from the ball.
Of all the things I've done, this was the easiest. Oh, don't forget to grease the ball before reinserting as this helps hold it in the post and lubes it too. Also, replace the outer spring going from the fork to the bell housing by the mounting bolts. (Someone else posted a pic of that) My clutch is now working the way it was intended. I hope this helps someone as much as this whole site has helped me.
MMA_Referee is offline
post #13 of 41 Old 11-27-2012, 07:59 PM
only in a jeep cj
Now that's thinking! and with good pictures too.
Ed
1975 CJ-6 1983 CJ-8
post #14 of 41 Old 11-28-2012, 05:50 AM
OleBlue73
1973 CJ5
It would seem you could remove the flywheel inspection cover on the front, bottom of the bell housing and the ball would be completely visible, if not roll right out. I don't remember the diameter of the ball in comparison with the clearance between the flywheel and bell housing. But at least you would see it and push it toward the fork opening.
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #15 of 41 Old 11-28-2012, 06:09 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Umm...does anyone have a pic of where this "pivot ball" is located? I see it pictured in the exploded view in my Haynes manual, but it's not clear where it installs.
I don't recall having one, when I installed my new clutch, but my clutch operates fine.
Can this ball be installed without dropping the trans?
Thanks,
Matt
Matt1981CJ7 is offline
Clutch Pivot Ball Install BigMike20 Jeep CJ Forum 15 05-30-2017 11:59 AM
Clutch Fork Pivot Ball?? luficer Jeep CJ Forum 3 09-02-2006 07:58 AM
Clutch fork pivot ball NCCJ7 Jeep CJ Forum 3 07-29-2006 12:07 PM
Clutch fork pivot ball Jeep Daddy Jeep CJ Forum 1 11-06-2005 08:07 PM
clutch fork pivot ball rustyCJ Jeep CJ Forum 3 12-24-2002 08:54 PM
