Clutch recommendations/opinions wanted - JeepForum.com
post #1 of 10 Old 04-02-2007, 08:47 AM Thread Starter
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
1976 304/T150/10-spline
Looking for clutch and throw out bearing replacement recommendations/opinions as in brand, model, etc.
Also, does the T150 have a 1 1/8 or 1 1/16 shaft?
PhatBasturd is offline
post #2 of 10 Old 04-02-2007, 09:29 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I would get a new stock application kit from my local FLAPS.
jeepdaddy2000 is offline
post #3 of 10 Old 04-02-2007, 12:23 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
From Jeeptech.com
The T-150 is a strong 3 speed transmission with a cast iron case. I has a casting number of 2603983 or 2603347 on the drivers side and 2603357 on top. The input shafts is 1 1/8" 10 spline and the output is 1 3/8" 6 spline.
Usage
The T-150 was used in CJs from 1976 to 1979.
Transmission 1st 2nd 3rd 4th 5th Rev
T-150 2.99 1.75 1.00 3.17
Cant tell you much about clutch stuff though... sorry
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #4 of 10 Old 04-02-2007, 02:57 PM
slacker92104
slacker92104's Avatar
Might save aq couple of bucks to use a chevy pickup disk instead of the jeep one. same shaft setup. We all know how the word jeep adds to the price of anything. You would need to find out what you're clutch diameter is.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #5 of 10 Old 04-02-2007, 03:15 PM
Matt in TN
1979 CJ7
Unless you're using some high HP engine, a stock clutch kit (disc, pressure plate, throwout and pilot bearing) from the local parts store is fine. I ordered a LUK clutch kit for mine, wanting to try something new - it seems to work fine, but makes a little whizzing noise with the clutch in. I've replaced the clutch linkage and triple-checked the adjustment and it is fully engaging and disengaging, but it still whizzes......
Join an off-road club!
'79 CJ-7, 304, T-18a, Dana 20, AMC-20 w/ Yukon 1-piece axles, and Dana-30, 33x12.50x15, 1" Body Lift w/ heavily trimmed fenders, full cage with seats and harnesses, CJ/Wagoneer power steering upgrade, custom front and rear bumpers, body armor, and belly-up skidplate
In the garage, waiting for hell to freeze over so I can finish the installation: Waggy front D44, AMC M23 rear
Matt in TN is offline
post #6 of 10 Old 04-02-2007, 04:44 PM
CJ5911
What ever you do dont use that crap from 4wd.com, i think its omix ada. I got 2 pressure plates from them that broke. After pulling my tranny more times then i should have I went with centerforce and I love it
1974 CJ 5 T-18 4 speed
Fiberglass tub, 1 piece front end, and windshield frame
350 Chevy bored 30 soon to be installed
CJ5911 is offline
post #7 of 10 Old 04-02-2007, 08:23 PM
Mastermind
Mastermind's Avatar
Generally, if you hear a noise with the pedal to the floor, it's your input shaft bearing. Did you replace that when you did the clutch?
'84 CJ7 258, Holley 4-bbl.
'97 BMW 318ti w/ S52 M3-Engine
Mastermind is offline
post #8 of 10 Old 04-03-2007, 03:08 AM
jeepmor
jeepmor's Avatar
Centerforce
I have a centerforce II in my 258/t-18 combo and it works great. I know a guy that had a Centerforce III and he burned it up on his toyota FWIW.
Whizzing noise is usually the throwout bearing in the clutches that I have had. I backed the fork off just a tad until it quit contacting. Mine also went away after driving it a while. I noticed this on a few cars that I've had. Once they break into my driving style as opposed to the previous owners. Odd that it would be this way, but sometimes it is. With a new setup though, input shaft or throwout bearing.
jeepmor
jeepmor is offline
post #9 of 10 Old 04-03-2007, 05:52 AM
mxg342
mxg342's Avatar
I put a Luk in my CJ. I used the 11" clutch when doing it. I like the clutch but the throwout bearing was junk in a year.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #10 of 10 Old 04-03-2007, 07:17 AM
Matt in TN
1979 CJ7
Yep - new pilot bearing and throwout bearing. What mxg342 says doesn't make me feel any better - the throwout bearing came greased, but it had a grease fitting. I put some more grease in just to make sure it was fully greased before installation, but the fitting doesn't give me the warm fuzzies. Hopefully it'll go away after driving it awhile.
1974 CJ5 opinions wanted please... Full Tank Jeep CJ Forum 17 04-03-2014 12:12 AM
opinions on a lift kit wanted mcurcio1989 Jeep CJ Forum 3 10-04-2009 08:21 PM
Opinions/Advice Wanted Kevmatic Jeep CJ Forum 2 07-18-2007 05:14 PM
Your opinions wanted on this CJ somewherre Jeep CJ Forum 7 03-24-2007 11:16 AM
Opinions wanted Pick01 Jeep CJ Forum 7 11-02-2006 06:03 PM
