Clutch rebuild problem - Page 3 - JeepForum.com
post #31 of 47 Old 09-29-2013, 07:25 AM
keith460
Jeep. There's Only One
keith460's Avatar
I don't think it will matter what kit you get as long as it is for the T176 trans and not for a T4/5. I think the TO bearing inside diameter is smaller on the T4/5 transmissions but I don't have my old front bearing cap around anymore to give you dimensions from but you would think they would be the same size.
You have to specify what transmission you have in your Jeep as the 'Parts Monkeys' just don't have the knowledge that several types and brands were available.
1984 CJ-7 Renegade
keith460 is offline
post #32 of 47 Old 09-29-2013, 09:30 AM Thread Starter
Gido
1980 CJ7
Advance auto gave me a full refund on the kit and replaced the part that broke due to a wrong TO bearing. So..... I looked up the part number to a LUK clutch kit and bought it. Everything will be in on tue and we should be putting it back in on thur. I will post up again when we get it back together. Thanks for the help everyone.
"At first you don't succeed, get a bigger Hammer!"
in memory of Jimmy Smith - a wise man
Gido is offline
post #33 of 47 Old 09-29-2013, 10:04 AM
LumpyGrits
Did you get a new seal that goes in the nose cap(sleeve)that broke?
Sounds like AA did the 'rite' thing, to help you.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #34 of 47 Old 09-29-2013, 04:15 PM Thread Starter
Gido
1980 CJ7
If the new bearing retainer cap doesn't come with one then no I haven't got one yet. I will look into that and see if I can get one ordered ASAP! I need a new one by thur so I can get it back together in time. Thanks again
Gido is offline
post #35 of 47 Old 10-01-2013, 02:53 PM Thread Starter
Gido
1980 CJ7
Originally Posted by LumpyGrits
Did you get a new seal that goes in the nose cap(sleeve)that broke? Sounds like AA did the 'rite' thing, to help you. LG
I ordered a seal for the retainer bracket. Going back together tomorrow night.
Gido is offline
post #36 of 47 Old 10-01-2013, 03:48 PM
LumpyGrits
Don't force anydangthing back together.
It either fits, or it doesn't........
Take your time!
LG
post #37 of 47 Old 10-01-2013, 04:01 PM
Krum81
1975 CJ5
My CJ had shims in the clutch mounting arm. If you shim that location it would allow a longer adjustment rod.
I lost mine when i pulled my clutch but replaced them with some drilled out flat bar steel.
Good luck
Krum81 is offline
post #38 of 47 Old 10-01-2013, 05:16 PM Thread Starter
Gido
1980 CJ7
My bro got all the parts in today and test fit everything. The TO bearing works with the new tranny bearing retainer cap sleeve, fits perfect on the clutch fork and fits on the pressure plate well (unlike the TO bearing from AA which didn't even touch all three arms). So, tomorrow night we r gonna put it all back together and see if we can get it ready for family vacation in Durahmtown next week. I will post up when done.
Gido is offline
post #39 of 47 Old 10-02-2013, 09:17 PM Thread Starter
Gido
1980 CJ7
Everything went together very nicely! New seal and retainer cap in place, new disc and pressure plate and new TO bearing all work together perfectly. Drove the jeep around for about 5 min. Thanks everyone for all the help and support!
For those reading this with a similar clutch problem, I ended up using a LUK clutch kit (which is awesome). Make sure you get some blue thread locker for your flywheel and pressure plate bolts and know that if my brother and I can do it just about anyone can do it, just have patience and take your time.
Gido is offline
post #40 of 47 Old 10-02-2013, 09:25 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Congratulations! Good job!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #41 of 47 Old 10-03-2013, 06:57 AM
keith460
keith460's Avatar
Feels good when something works out for the better!
1984 CJ-7 Renegade
keith460 is offline
post #42 of 47 Old 10-03-2013, 07:15 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
You're not kidding!
The taste of victory is sweet!
Max
Mean Max is offline
post #43 of 47 Old 10-03-2013, 07:50 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Strong work, Max. Congrats!!
Matt
Matt1981CJ7 is offline
post #44 of 47 Old 10-03-2013, 10:30 AM
keith460
keith460's Avatar
Matt
It was actually Gido who did the work.
1984 CJ-7 Renegade
keith460 is offline
post #45 of 47 Old 10-03-2013, 12:55 PM
Matt1981CJ7
1981 CJ7
Sorry, Gido. I read thru the thread too fast.
I'm sure Max did something worth congratulating, too.
Matt
