Clutch rebuild problem - Page 2 - JeepForum.com
post #16 of 47 Old 09-12-2013, 06:19 PM
LumpyGrits
Now, confirm the chutch is the correct PN for your Jeep.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #17 of 47 Old 09-12-2013, 06:30 PM Thread Starter
Gido
1980 CJ7
LG
I will do that when I pull it back off.
"At first you don't succeed, get a bigger Hammer!"
in memory of Jimmy Smith - a wise man
Gido is offline
post #18 of 47 Old 09-12-2013, 06:32 PM
LumpyGrits
Don't you have the box/wraper etc it came in?
Isn't there a PN on your receipt?
LG
post #19 of 47 Old 09-12-2013, 06:56 PM Thread Starter
Gido
1980 CJ7
LG
The box, receipt and jeep r at my brothers house two hours from me. I could get him to get the numbers off the box for me.
Gido is offline
post #20 of 47 Old 09-12-2013, 07:06 PM
walkerhoundvm
1981 CJ8
The clutch kit I bought from Autozone did not fit correctly or work for me. I ended up having to source a LuK kit, which works like a dream. YMMV
walkerhoundvm is offline
post #21 of 47 Old 09-12-2013, 07:33 PM Thread Starter
Gido
1980 CJ7
I got mine from advance. What was the cost of the LuK kit? It may be that the pressure plate is to thick. Did autozone take it back?
Gido is offline
post #22 of 47 Old 09-12-2013, 07:57 PM
walkerhoundvm
1981 CJ8
Yes - they took it back, it's kinda important if they sell you a part that doesn't work with your vehicle
The LuK kit was about $150. Forget the part number, but Napa didn't have it and they had to refer me to a local tranny shop who ordered it and had it to me in 24hrs.
post #23 of 47 Old 09-13-2013, 05:11 AM Thread Starter
Gido
1980 CJ7
Thanks for the info!
Gido is offline
post #24 of 47 Old 09-28-2013, 06:03 PM Thread Starter
Gido
1980 CJ7
Late night but my bro and I are about to pull the tranny and bellhousing. I will let y'all know what we find out.
Gido is offline
post #25 of 47 Old 09-28-2013, 06:47 PM
jennkent5454
1979 CJ5
Im dyin to know, please share!!!!
jennkent5454 is offline
post #26 of 47 Old 09-28-2013, 08:23 PM Thread Starter
Gido
1980 CJ7
Just got it pulled. Looks like something was wrong with the TO bearing. The bearing retainer cap sleeve is sheared off at the cap like the TO bearing bound up or was to small. Suggestions?
Gido is offline
post #27 of 47 Old 09-28-2013, 08:29 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You need a new bearing retainer, and then verify that your parts will work together.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #28 of 47 Old 09-29-2013, 06:11 AM
keith460
Jeep. There's Only One
keith460's Avatar
Your original front bearing cap must have been weak for it to shear off like that. I believe the T176 bearing caps are made of cast iron.
Was their any grease or lube on the front bearing cap tube portion for the TO bearing to slide on? Shearing the tube off like that seams as though the TO bearing has seized and the friction generated between the pressure plate and the TO bearing was to much for the bearing cap and sheared it off.
Time for a new one and don't forget to purchase a new seal that is inside the front bearing cap plus a new gasket.
Quadratec has them: http://www.quadratec.com/products/52129_01.htm
1984 CJ-7 Renegade
keith460 is offline
post #29 of 47 Old 09-29-2013, 06:28 AM Thread Starter
Gido
1980 CJ7
Yeah, I put some grease on it. This is the first time I have rebuilt a clutch and I guess I'm destined to learn the hard way. I should have checked the fit of the TO bearing on the sleeve before we put it together. We were wondering why it was so difficult to push in. I guess we know now. The old TO bearing slides perfect on the sleeve. The new one binds up like it is to small. And the overall diameter of the bearing (that sits on the spring release on the pressure plate) is smaller than the old one. Now I need to get parts ASAP to get it fixed for family vacation.
Gido is offline
post #30 of 47 Old 09-29-2013, 06:39 AM Thread Starter
Gido
1980 CJ7
I guess the big question is, should I just take back the advance kit and go with a LUK kit or attempt to replace the bearing retainer cap and see if the advance kit will work with the new cap?
Gido is offline
