Clutch questions 79 CJ - JeepForum.com
post #1 of 4 Old 09-28-2011, 07:03 PM Thread Starter
imafishingfred
imafishingfred's Avatar
1981 CJ7
My son bought a 79 CJ7 all original 304, 3sp. Previous owner had removed tranny to put in new clutch but never got around to it. We have everything except the old clutch disc, pressure plate, and throwout bearing. Advance has 2 different clutch kits listed. How do I determine which of the 2 we need?
Here are the 2:
http://shop.advanceautoparts.com/web...1251173457____
http://shop.advanceautoparts.com/web...1251168221____
Thanks,
Fred
imafishingfred is offline
post #2 of 4 Old 09-28-2011, 07:40 PM
mopar408
1974 CJ5
almost positive ( that and 2 bucks'll get coffee at Starbucks) that it's the Borg and Beck ( 3 finger) style.
Thinking the diaphragm came on later
If you don't get a better answer, better than a coin toss.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #3 of 4 Old 09-28-2011, 07:59 PM
BagusJeep
1981 CJ7
There were two different size clutches, one 10.5" and one 11" driven plate diameter fitted to CJs. yours should have been fitted originally with the 10.5" diameter, shared with some 6 cyl CJ7s.
The reason I mention this is because there are different cover plates depending on size. You need one that will line up with the holes on your flywheel. From the parts manual it appears the same flywheel was used for 10.5" and 11" clutches on the 6 cyl CJs so either cover plate would bolt up.
As to which one of these will fit, hard to say what the differences are apart from the diaphragm style. I have the second type and it works. Always buy it with a new release bearing.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 4 Old 09-28-2011, 08:10 PM
mopar346
Either will work, bolt pattern the same and TOB contact the same OR you could up grade to a 11 inch, the flywheel is the same and the bell housing clears without issue. The diaphram style offers less leg pressure, but I agree that it was used later in the CJ run, as I understand it anyway. I switched mine from a 10.5 to a custom built 11 with heavier springs and stayed with the 3 finger style. If you have a local clutch rebuilder left in town go have one built and they should be able to resurface and balance your flywheel as well.
AND 2 buck will not buy a cup of starbucks.
Careful your character's showing
mopar346 is offline
clutch questions? heisman01 Jeep CJ Forum 2 07-21-2011 07:51 PM
80 CJ7 Clutch and T-176 questions tlhigh Jeep CJ Forum 7 04-14-2009 06:55 AM
CJ clutch linkage questions dave1234 Jeep CJ Forum 1 07-18-2008 04:02 PM
cj 7 clutch questions outdoordad@comc Jeep CJ Forum 2 10-20-2005 07:16 PM
clutch questions tera1298 Jeep CJ Forum 1 08-06-2003 07:21 PM
