Clutch Problems - JeepForum.com
post #1 of 3 Old 04-27-2006, 08:00 PM Thread Starter
medunwoody
Clutch Problems
We just got done replacing the clutch on our 79 CJ7. We ended up replacing the pressure plate, pilot bearing, and throwout bearing. When we got it all back together, it worked fine for about a week until the throwout bearing started chirping. When you push in the clutch, there is a noticeable chirp from the bearing. Also, as you release the clutch pedal while the engine is running, the pedal catches and feels almost as if i won't engage fully. However, when the engine is off, it is very smooth without any problems. Does anyone have any idea what this could possibly be?
1985 CJ-7 with 4bt Cummins Turbo Diesel, nv4500, dana 300, 4.56 gears in stock axle housings just waiting to blow up with the extra power!
Columbia, MO
medunwoody is offline
post #2 of 3 Old 04-27-2006, 09:08 PM
mr_frenchy
Which transmission? is it stock tranny?
Found this Service bulletin a while ago, might help....
LB133 - Critical Release Bearing/Fork Match
Release bearing/fork combinations differ among models, and the parts are not interchangeable. The wrong combination will result in chatter and hard pedal when the fork contacts the bearing retainer. Following is a description of how to identify the two types.
Models through 1979 used a fork with two small pin-type locators at the bearing end. The locators fit into holes drilled in the release bearing plate under the clips. When installing the release bearing, ensure the locators fit all the way inside the holes in the release bearing plate.
After 1979 the fork had no locator pins. Instead it was centered by a release bearing collar that extended beyond the back of the bearing between the bearing retainer clips. When replacing the fork, ensure it is wide enough to pass freely over the centering collar.
'75 CJ5, SOA, 36" buckshots, Warn 9000i upfront, 304 V8
In the Bible some where it says that if you sell your Jeep to buy a honda, you'll go to hell. It's somewhere in the back, near the maps.
mr_frenchy is offline
post #3 of 3 Old 04-28-2006, 04:59 PM Thread Starter
medunwoody
Clutch Problem
The transmission is a T-150. The engine is the 258. The transmission is stock but the jeep originally had a 304 in it but was switched out with a '79 258. The throwout bearing that we put in looks identical to the one we took out. There weren't any problems until we put in the new clutch.
Columbia, MO
Possible Clutch Problems??? CJ5 78 Jeep CJ Forum 6 06-07-2007 05:36 PM
clutch problems Backcountry Jeep CJ Forum 4 01-03-2007 03:48 PM
Clutch problems? jeepsarecool Jeep CJ Forum 5 03-28-2006 09:56 AM
Clutch problems 79CJ54wheeler Jeep CJ Forum 7 09-28-2005 06:49 PM
clutch problems manhattanjeep Jeep CJ Forum 1 10-10-2002 01:11 AM
