clutch problems - JeepForum.com
post #1 of 2 Old 10-06-2002, 10:15 AM Thread Starter
manhattanjeep
clutch problems
Well I got a new linkage put in a couple days ago. But I have another problem. When I was out wheeling last Saturday, the Jeep started lunging and jerking when I would take off in 1st or Reverse. Well I adjusted the clutch, but on the next obstacle the linkage popped apart, and ended up popping apart often. Now that everything is back together, there is no more lunging when taking off in 1st, but it is still there when trying to back up. I am at a loss as to what this may be. I think it may be the throwout bearing, because I am not sure if it was replaced when the clutch was. Flame away, I was scared to tackle a clutch back then. The clutch is only a year old, and has only gotten hot once or twice that I know of, as I am running 32's on 3.54 gears. I plan on driving this 100 miles each way on Monday afternoon, so I would like to have it fixed, so as not to have to find another way to make this trip.
76 CJ5
Real Jeeps are not bought, they're built!!!
manhattanjeep is offline
post #2 of 2 Old 10-10-2002, 02:11 AM
Jeep Daddy
Jeep Daddy's Avatar
Check your motor mounts and the transmission mounts. Especially check the transmission stabilizer bushings. If the throw out bearing is bad, you'll hear a lot of noise everytime you push in the clutch.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
Possible Clutch Problems??? CJ5 78 Jeep CJ Forum 6 06-07-2007 06:36 PM
clutch problems Backcountry Jeep CJ Forum 4 01-03-2007 04:48 PM
Clutch Problems medunwoody Jeep CJ Forum 2 04-28-2006 05:59 PM
Clutch problems? jeepsarecool Jeep CJ Forum 5 03-28-2006 10:56 AM
Clutch problems 79CJ54wheeler Jeep CJ Forum 7 09-28-2005 07:49 PM
