Clutch problems - JeepForum.com
post #1 of 8 Old 09-26-2005, 06:49 PM Thread Starter
79CJ54wheeler
Clutch problems
ill start by admitting that i am not too familiar with working on the clutch....just havent had to do much of it yet on my CJ. so the clutch has been grabbing pretty high off the floor and i was having trouble adjusting it (jam nut is between transmission + header = pain in the a$$ to reach) so i took it to a local shop. we ended up dropping the linkage in order to adjust it and they told me that it is all the way adjusted out and that i am due for a new clutch soon. is 6-8 hrs labor on a clutch normal? thats what they told me so now obvioulsy i am thinkin about doing it myself. is any special experience needed or is it fairly simple to figure out the first time. thanks for any input you guys got.
79 CJ5 304/T18/Dana 20/30/20(alloy's + locked)
79CJ54wheeler is offline
post #2 of 8 Old 09-26-2005, 06:55 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
I can't say on pro labor times. It's fairly simple, but it helps to have a friend at times to line th tranny back up, and you will need to keep track a of bunck of small parts, but check out an FSM or even Haynes for some idea what to expect.
Overall, everything has to be "just right" or it will work like crap.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 8 Old 09-26-2005, 07:25 PM Thread Starter
79CJ54wheeler
yea i was thinkin a centerforce....atleast thats what ive heard good things about. the whole job dosen't seem too difficult but my jeep is my daily driver so id like to find out about unseen problems now.
post #4 of 8 Old 09-27-2005, 06:29 PM Thread Starter
79CJ54wheeler
ya guys think it could be done in a weekend?
post #5 of 8 Old 09-28-2005, 06:18 AM
jadams68
jadams68's Avatar
Centerforce is super expensive.... Try LUK clutches... they work great and they are cheap in comparision...
www.dialaclutch.com
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #6 of 8 Old 09-28-2005, 08:12 AM
Mud Machine
Jeep Addict
Mud Machine's Avatar
I bought a Centerforce and am very happy. Don't go to cheep it you are running big tires or high power. No sense doing the job twice. If you can get a tranny jack it will make your life much easier. I borrowed a tranny jack and did the entire job by myself in very little time. Removed the crossmember with the tranny and transfer case still attached all as one unit. This is a huge time saver. The job could easily be done in a weekend or even in one day or less if everything goes good. As you know this isn't always the case. If you cant locate a jack then have a strong friend with you for help. Keep in mind that you will need to have the flywheel resurfaced at a locate machine shop which will cause a delay in how long the job will take. Maybe if you talk to them in advance they will do it for you as soon as you bring it in so you can have it back in an hour or so. You will also need a special tool to remove the bearing (or bushing depending on what you have) in the crankshaft. Make sure you replace this. Check with your local auto parts store as most will rent a tool to you for a fully refundable deposit when you return the tool. If you can't find one I can give you a couple other ideas on how to remove this without the tool but it will take a bit longer to do. Tool is fast and works very nicely.
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #7 of 8 Old 09-28-2005, 08:40 AM
jadams68
jadams68's Avatar
I ran a LUK clutch for years... I only replaced it because I rebuilt the motor and had to replace the throwout bearing...so I figured why not?
I run 35"s by the way....
jadams68 is offline
post #8 of 8 Old 09-28-2005, 06:49 PM Thread Starter
79CJ54wheeler
yea unfortunaly i know how that goes so with a tranny jack and this special tool i should be good to go. thanks for the input, feel a lilttle more comfotable about doing it now.
Possible Clutch Problems??? CJ5 78 Jeep CJ Forum 6 06-07-2007 05:36 PM
clutch problems Backcountry Jeep CJ Forum 4 01-03-2007 03:48 PM
Clutch Problems medunwoody Jeep CJ Forum 2 04-28-2006 04:59 PM
Clutch problems? jeepsarecool Jeep CJ Forum 5 03-28-2006 09:56 AM
clutch problems manhattanjeep Jeep CJ Forum 1 10-10-2002 01:11 AM
