Clutch problem - JeepForum.com
post #1 of 12 Old 11-01-2013, 07:07 AM Thread Starter
Mikebaxter
1979 CJ7
Clutch problem
The jeep recently started having a problem with speed and acceleration. I thought it was a brake problem until I was driving down the road and I heard a real loud zip noise and the clutch just went dead. I'm assuming that it had an effect on the power and I was wondering if putting a new clutch in would fix the deadness or is there more than it seems. It's never a simple fix when working on this thing.
Mikebaxter is offline
post #2 of 12 Old 11-01-2013, 07:08 AM
davbytrace
1979 CJ7
Need a little more info....
davbytrace is offline
post #3 of 12 Old 11-01-2013, 07:13 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
What's a "1981 scrambler motor"?
Matt
Matt1981CJ7 is offline
post #4 of 12 Old 11-01-2013, 08:20 AM
ScroungerLee
Can you define "dead"? The pedal went to the floor? The clutch won't engage at all? Other?
ScroungerLee is offline
post #5 of 12 Old 11-01-2013, 10:31 AM
mastercraftka
mastercraftka's Avatar
ya what he asked.
1984 CJ 7
1948 CJ 2A
1982 CJ 7
1981 CJ 7
mastercraftka is offline
post #6 of 12 Old 11-02-2013, 09:56 AM Thread Starter
Mikebaxter
1979 CJ7
I'm new to the jeep world soon trying to explain the best i can. I know the clutch was having problems when I shifted. It had way to much play in every gear and it constantly friended going into first and reverse and when I slowed down to fast it would grind. When I heard the the noise I lost all the gears but there's still pressure on the pedal
post #7 of 12 Old 11-02-2013, 11:36 AM
walkerhoundvm
1981 CJ8
Sounds like more of a transmission problem to me
walkerhoundvm is offline
post #8 of 12 Old 11-02-2013, 01:18 PM
ScroungerLee
I agree, it sounds like a transmission failure. What transmission was it? Your profile doesn't say.
post #9 of 12 Old 11-02-2013, 02:41 PM Thread Starter
Mikebaxter
1979 CJ7
I don't know what kind it was. There's so many different years parts on it that I still don't know what it is. It may be out of a cj-8 because that's what the engine and transfer case is
post #10 of 12 Old 11-02-2013, 03:28 PM Thread Starter
Mikebaxter
1979 CJ7
Are*
post #11 of 12 Old 11-04-2013, 11:31 AM
mastercraftka
I agree! synchros? cracked gears?
My T4 would grind going into 1st gear pulled it out and 1st gear was cracked.
1984 CJ 7
1948 CJ 2A
1982 CJ 7
1981 CJ 7
post #12 of 12 Old 11-04-2013, 12:05 PM
Spieg8
1984 CJ8
How many speeds does the transmission have?
5spd would probably be a T-5
4spd would likely be T4, SR4, or T176 (maybe something else depending on what swaps may have been done).
Have you checked the fluids (transmission lube)?
Maybe take some pictures to help with identification.
Spieg8 is offline
