Clutch/Pilot Bushing Install Question? - JeepForum.com
post #1 of 19 Old 02-27-2014, 07:23 AM Thread Starter
cdt540
1983 CJ7
I am about to install the new clutch and tranny to my newly rebuilt motor.According to the FSM and other posts I am supposed to install a oil soaked "wick" with the new pilot bushing. Since I will be cutting my own felt to make the wick my question is this. Is the wick the same size as the outside diameter of the pilot bushing and go in before the bushing or is it the same size as the inside diameter of the P bushing and go inside the P bushing after it is installed? Thanks for any help....
Chris
'83 CJ7 (258 4spd)
Austin TX
cdt540 is offline
post #2 of 19 Old 02-27-2014, 07:50 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I think the factory wick is an oversized sponge, like 3" in diameter, and it stuffs into the hole in front (engine side) of the bushing.
I've read that the wick is somewhat redundant, since the bushing is oil-impregnated bronze. I hope that's accurate, because I'm not running one.
Matt
Matt1981CJ7 is offline
post #3 of 19 Old 02-27-2014, 08:01 AM
dhubbs
1979 CJ5
The one I just did was larger like Matt said. It was kind of folded in half and more of a square piec rather than round. I dont think there is an exact science to the wick.
dhubbs is offline
post #4 of 19 Old 02-27-2014, 08:32 AM
chromegrille
1947 CJ2A
It goes in before you install the bushing.
chromegrille is offline
post #5 of 19 Old 02-27-2014, 08:38 AM Thread Starter
cdt540
1983 CJ7
Thanks all. I will get a better picture once I get the motor off the engine stand and can get a good look at what I am dealing with.
Chris
cdt540 is offline
post #6 of 19 Old 02-27-2014, 09:58 AM
CSP
Drop your bushing into a small cup of oil the night before the install and let it soak up as much oil as possible.
CSP is offline
post #7 of 19 Old 02-27-2014, 11:05 AM
Mike Romain
I used a bolt the size of the pilot shaft to remove my old pilot. I might have wrapped a couple wraps of black tape on it to make it snug. I filled the cavity behind full of grease, put the bolt in the filled up with grease hole and gave it a good thump with a dead blow hammer. The pilot popped right on out.
My wick was reusable after cleaning and yes you need one to keep the pilot in good shape. Figure it is open to water if you get in deep enough.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline
post #8 of 19 Old 02-27-2014, 06:28 PM
JeffreyCharles
1976 CJ5
I cut mine (the old one was missing) to the OD of the bushing, then put it in place before installing the bushing.
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #9 of 19 Old 03-13-2014, 06:58 PM
dslywalker
1983 CJ7
Got my bushing out with moist bread instead of grease.Much cleaner
Jeep Naked
Put some color in your Cheeks
dslywalker is offline
post #10 of 19 Old 03-14-2014, 06:37 AM
Mike Romain
I like that one, will remember it.
Mike
post #11 of 19 Old 03-14-2014, 01:16 PM
CSP
Wet paper towel is my weapon of choice.
CSP is offline
post #12 of 19 Old 03-23-2014, 08:00 AM
banjerman
Couldn't get mine out with grease, so stuffed some hot dog bun in with the grease. Worked like a charm.
banjerman is offline
post #13 of 19 Old 01-24-2016, 09:02 PM
STJP
STJP's Avatar
Resurecting an old thread.....so is there a consensus on pilot bearing wick diameter and thickness??
I understand it goes in before the bearing, thus can presume it could be made too large or too small to be effective. I also understand many do not install a wick, but why not if installing a new bearing?
Cheers,
John
STJP is online now
post #14 of 19 Old 01-24-2016, 10:20 PM
RedNeckCorvette
1979 CJ7
First I used grease, as time went by I used a tap it as it is much cleaner and more positive than grease just pushing out a bronze bushing.
Sure enough, as soon as I could afford one I purchased the correct puller and have had many other uses for it since then. It has been a pleasure to lend it to my how do you get this thing out friends, next hearing wow that was easy I need to get one of those.
RN
RedNeckCorvette is offline
post #15 of 19 Old 01-25-2016, 01:05 AM
STJP
STJP's Avatar
RN, what is the correct puller?
Can you address my wick question?
Cheers,
John
STJP is online now
