Clutch Pedal Vibration 4.2L 5-Speed Borg-Warner T-5 - JeepForum.com
post #1 of 10 Old 08-12-2009, 08:26 AM Thread Starter
ddumbauld
1982 CJ7
I've got a 1982 CJ-7 4.2L 5-speed B-W transmission with a new clutch (<4000 miles). The previous owner had it installed so I don't know what brand clutch they installed.
I've had the Jeep for about 3000 miles and I've noticed that the clutch pedal vibrates - and it seems to be getting worse. When the engine/drivetrain are cold, I don't feel the vibration. However, when things start to heat up after a few miles of driving, the clutch pedal begins to vibrate.
I can feel the vibration on my foot if I gently put pressure on the pedal. Pressing the clutch pedal to the floor stops the vibration. The vibration occurs when I'm in gear or in neutral, both stopped and rolling.
Any ideas on where I should start the troubleshooting??
ddumbauld is offline
post #2 of 10 Old 08-12-2009, 08:32 AM
bz79jeepcj
1979 CJ7
My first thought would be the Throw out bearing.
bz79jeepcj is offline
post #3 of 10 Old 08-12-2009, 08:42 AM
moonpie312
X2 on the throwout bearing
moonpie312 is offline
post #4 of 10 Old 08-12-2009, 10:46 AM Thread Starter
ddumbauld
1982 CJ7
Throw-out bearing?
Thanks for the responses guys.
What about the throw-out bearing would cause the vibration? Why would it depend on the temperature of the system?
I've never installed one of these before, so could the problem be a parts failure or an installation failure?
How much am I looking at to get this fixed? It's got to be putting a lot of unneeded stress on things.
post #5 of 10 Old 08-13-2009, 09:44 AM
moonpie312
Well, throwout bearings are under a lot of pressure, My first guess as to why it would be the throwout bearing, would be the PO didnt replace it when they put in the new clutch, and even if they did, I have got new bearings that went bad very fast. As for the temperature issue, well it could be that the grease in the bearing, when it gets heated up gets thin probably because there isnt much in there to start with, and without very good lube, well you do the math. I believe more and more that it is the throwout bearing because sometimes when one is just starting to go bad, just a hint of pressure it will make all kinda of vibration and racket, but when put under extreme load, it will go away. And that being the case, that means it will probably be toast soon, but then again it may last for another few thousand miles. Good news is it it does lock up, and your off somewhere, you can always just start it in gear and shift it without the clutch until you get home, avoiding as many stops as possible. That is of course if you can shift a standard without the clutch?
post #6 of 10 Old 08-13-2009, 10:09 AM
1986cj
x2 or more on the clutch release bearing. If they had got a "kit" from Checkers or the likes don't waste your time, go get a good bearing and be done with it. I have a 86, same set up and first the pilot bearing was wrong three times and I had replaced the clutch release bearing twice before going and getting a Timken bearing. Twice the price of the china one in the kit but now a firm believer of you get what you pay for.
1986cj is offline
post #7 of 10 Old 08-13-2009, 06:44 PM Thread Starter
ddumbauld
1982 CJ7
Thanks guys. I have a good relationship with the PO. I'll get some more details on the components he used.
I decided to run the Jeep over to a local shop that does really good work. The mechanic took 1 look at it and said that he thought it might be the throw-out bearing. This was based on experimenting with how far the clutch pedal comes out before the engine stalls (tranny in 2nd gear). After the engine dies out, the clutch has another 5-6 in. of travel before the pedal is completely released. The mechanic thinks that the throw-out bearing might be too far away from the pressure plate when the pedal is out. He said that the bearing should always ride against the plate. If it doesn't - it can sort of rattle around and cause vibration. Sounds legitimate enough. I'll keep you posted.
How difficult is it to replace the clutch and components? Do I need special tools?
post #8 of 10 Old 08-14-2009, 07:45 AM Thread Starter
ddumbauld
1982 CJ7
Clutch needs to be taken apart
Guys,
My mechanic adjusted the pedal travel without any luck reducing the vibration. He has recommended rebuilding it .
What is the best clutch kit to use? Timken bearings are a must, obviously.
Any other components that I should consider replacing while they're in there?
Thanks for all of your help,
Dave
post #9 of 10 Old 08-14-2009, 12:48 PM
Mike Romain
I would first find out what the previous owner did.....
It is expensive to have someone do a re and re on the clutch.
That said, I prefer the stock borg warner clutch and pressure plate, I tried a centerforce type with all the fingers and it burned out one month out of warranty, so I put the old BW pressure plate back in. The cenertforce was also very heavy on the foot with the mechanical linkage.
Hmm, clutch pedal had vibration and dropped down with time. Problem was in the front bearing cap the throwout slides on, the previous owner rode his foot on the clutch pedal and wore a notch in the snout of the cap which hung up the new bearing. I would check for that if you open it.
Mike
Mike Romain is offline
post #10 of 10 Old 08-14-2009, 01:03 PM Thread Starter
ddumbauld
1982 CJ7
Thanks Mike. The shop said they can do the whole thing for $550 (parts & labor, excluding flywheel replacement).
I'm trying to get a hold of the PO to see if this might be under the warranty. Probably not, but if they're a decent shop I would think they could make this right.
I'd spring for the BW parts if the shop we do the labor.
This isn't the type of job I'm equipped for right now.
Borg Warner T5 Help!! cgi2099 Jeep CJ Forum 21 11-10-2011 09:57 AM
Borg-Warner T5 Quill Jeep CJ Forum 7 08-31-2009 05:21 PM
amc 360 to borg warner SR4 hauser33 Jeep CJ Forum 6 05-06-2009 10:40 PM
Borg Warner 5 speed transmission ecil Jeep CJ Forum 5 04-19-2009 06:57 AM
Borg Warner "Brute Power" clutch kits..anyone tried one? Full Tank Jeep CJ Forum 2 03-24-2008 09:10 PM
