Clutch pedal return spring - JeepForum.com
post #1 of 11 Old 07-03-2010, 10:33 AM Thread Starter
Mjbb04
I baught a new pedal return spring, it appears to be too long. Any pictures on how this is supposed to hook up. I have an 86 Cj. There is not a hole in the clutch pedal to put the spring through. Do I have the right spring?
Mjbb04 is offline
post #2 of 11 Old 07-03-2010, 10:44 AM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Are you referring to part #25
Jeep Clutch Parts for Jeep CJ5, CJ7, CJ8, Scrambler at Morris 4x4 Center
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 11 Old 07-03-2010, 10:46 AM
keith460
Jeep. There's Only One
keith460's Avatar
Here you go, there's a small hole next to the pin that holds it in place. Disregard the arrow pointing to a bushing as that was for another posting in the past.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline
post #4 of 11 Old 07-03-2010, 11:03 AM
Obnoxious1
1981 CJ5
Coiz posted some great pics of the assembly at the following post
http://www.jeepforum.com/forum/f8/cl...l-assy-763822/
Err never mind.. Keith beat me to it
Jeep –noun (jēp)
A Four wheel mechanized device surrounded by glass and metal designed for the frequent consumption of the owner/operator's money. Jeeps are also linked to diseases such as Jeep envy which can be diagnosed by unusual urges for items such as bigger tires,lift kits, shocks and AMC 401s. As well as the urge to pour money into more than one Jeep. Side effects may be spouse accruing numerous "honey-do's", as well as trips to inlaws. Grease under your nails, numerous trips to NAPA and junk yards, and spare parts in the attic may indicate an addiction. There are no known cures. However there are support groups such as JeepForum.com
Obnoxious1 is offline
post #5 of 11 Old 07-03-2010, 11:57 AM Thread Starter
Mjbb04
it is part number #25. it looks a lot different than the yellow posted. It is supposed to work. did you have to cut some of the length off and bend it?
Mjbb04 is offline
post #6 of 11 Old 07-03-2010, 10:09 PM
I6CJ7
Is that spring really even necessary? mine doesn't have it and my other CJ had one that was never connected and it all worked fine, nice light pedal pressure though.
I6CJ7 is offline
post #7 of 11 Old 07-04-2010, 05:23 AM
keith460
keith460's Avatar
The yellow spring shown, powder coated by the way, is an original for 1984 and your 86' will be the same. There is a difference in spring length after about 1982 when AMC/Jeep changed the upper portion of the pedal and got rid of the extension to mount a longer spring that were prone to popping off. So they shortened the riveted spring bracket attached to the pedal in favor of using a shorter spring with a pin to hold it in place. You can see the difference form the picture I posted to the one from Coiz that is posted here: http://www.jeepforum.com/forum/f8/cl...2/#post7116645
1984 CJ-7 Renegade
keith460 is offline
post #8 of 11 Old 07-04-2010, 03:47 PM Thread Starter
Mjbb04
Keith, thanks for the help. So i ordered the spring and said it was for an 86 jeep but got the longer spring not the short one shown in your picture. Where do i order the original size spring? This is the second time I have ordered that spring and the second time I got the long one.
Mjbb04 is offline
post #9 of 11 Old 07-05-2010, 12:34 AM
keith460
keith460's Avatar
Have no idea where to get that one. Some other people have tried getting that spring before but have had no luck as far as I know.
1984 CJ-7 Renegade
keith460 is offline
post #10 of 11 Old 07-05-2010, 04:46 AM
southshore30
1982 CJ7
I just got one for mine at the local hadware store. They had a huge selection and only required a slight snip and a minor re bend at one end all for less than $4. It works just fine returning the pedal back up to its stop.
Firefighters Jeep Club
SBC350,T-176,D-300,D44
southshore30 is offline
post #11 of 11 Old 08-05-2016, 01:47 PM
jeepdog571
1983 CJ7
Has anyone found the shorter clutch pedal spring like the yellow one in keith460 picture. Mine is missing and all I can find is the longer one. Thanks
jeepdog571 is offline
'81 CJ Clutch Pedal Return Spring Woes RARECJ8 Jeep CJ Forum 5 06-28-2011 09:07 AM
Brake Pedal Return Spring ? pu70 Jeep CJ Forum 3 09-09-2008 08:06 AM
clutch pedal return spring? wjb4000 Jeep CJ Forum 3 02-07-2008 06:17 AM
Clutch Pedal Return Spring Fustration big G Jeep CJ Forum 8 03-09-2007 07:54 PM
Brake pedal return spring Vinnyl32 Jeep CJ Forum 1 02-22-2006 06:03 PM
