clutch pedal assembly/pushrod help - JeepForum.com
post #1 of 7 Old 10-11-2007, 07:55 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
Thought I had good pictures of the old tub but don't. Installed the original CJ7 clutch pedal assembly on the 95 YJ tub and it doesn't fit..too long by about an inch. Does that sound right to anyone else who has made this swap? Do I have the pedal assembly at the wrong angle and that is why it is too long? Of course I tried to adjust the pushrod and it is corroded. This is day 6 of soaking in pb blaster. I just want to make sure I have the pedal assemble in correctly. Right now I cannot even get the push rod inside the throw out lever cup.
I am so close to getting this thing going!!! Aaaaaaah!
TetanusCJ7 is offline
post #2 of 7 Old 10-12-2007, 07:42 AM
aero mech
aero mech's Avatar
1980 CJ7
Looks correct to me, I would need to see the other side to be sure. As for it being to long, i am not sure about that. If it is frozen up you can purchase new ones or an whole kit that includes the whole assemble for around 60.00 from places like jeepdoc.com, 4wd.com or quadrete.com. PO of my jeep added a 4 inch body lift and mine was adjusted way out. Hope this helps jc
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #3 of 7 Old 10-12-2007, 07:45 AM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
thanks aero. I just looked at the quadratec kit for around the same price. I just wanted to make sure that I put it back in correctly. Mine is adjusted way out and frozen there.
post #4 of 7 Old 10-12-2007, 08:00 AM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
PB blaster to the rescue (over about 6 days). Just broke it free and is now adjustable! Does the rod just sit against the throw out rod with pressure or should there be a clip or something to keep it from flopping out?
post #5 of 7 Old 10-12-2007, 08:59 AM
aero mech
aero mech's Avatar
1980 CJ7
Just sits against the arm. thetension of the clutch spring holds tension on it. jc
post #6 of 7 Old 10-12-2007, 06:10 PM Thread Starter
TetanusCJ7
TetanusCJ7's Avatar
1978 CJ7
got it, thanks!
post #7 of 7 Old 10-12-2007, 07:43 PM
Fuzz21
Fuzz21's Avatar
I just bought the kit from jc whitney for 59.99 and yep no clip just sits there. that was the only thing i forgot to take off before i removed the old tub sooooooo thats why i had to replace the entire thing.... it broke!!!
1985 CJ-7, 258 w/a weber carb and HEI, 2.5"lift w/32" tires, 1/2"shackle lift, Dana 300, T-5, AMC 20 w/one piece axels, and Dana 30, YJ tub swap w/CJ tailgate, chevy blower motor upgrade, homeade body sliders, flush mount LED taillights......much more to come!!
"And on the eigth day, Man created BEER!"
Fuzz21 is offline
Mounting E-brake pedal assembly to fiberglass body chet44 Jeep CJ Forum 4 10-12-2009 11:27 AM
Looking For A Gas Pedal Assembly? JimbtheBuilder Jeep CJ Forum 5 08-16-2009 07:33 AM
Installing pedal assembly? Sedorbrian Jeep CJ Forum 1 04-02-2009 05:09 PM
Master Cyl. Clutch Pushrod, Any Ideas? Aphelion79 Jeep CJ Forum 5 08-06-2006 09:34 AM
How do you remove the pedal assembly? cjthor Jeep CJ Forum 2 10-25-2004 08:42 AM
