Clutch noise: In neutral with pedal disengaged - JeepForum.com
post #1 of 13 Old 04-15-2012, 08:37 PM Thread Starter
pman
Have any of you had experience with your clutch making a "lop-lop-lop-lop" sound with the transmission in neutral and the clutch disengaged? The sound disappears when you depress the clutch pedal. I've tried to research it, and I've come up with two possibilities:
1) input/pilot shaft bearing problem
2) I've got to find the specifics again, but I read something this weekend online that suggested the "rubber" on the center of the clutch could be worn?
The drivetrain is a 304 mated to a T150 w/ a Dana 20 TC. I just purchased this CJ5 from a neighbor a few weeks ago, and have been elbow deep in body work, and am now going through the mechanicals. I'm wondering if this problem could also be why I have drivetrain vibes when get over 20mph (Edit-UJoints have already been replaced to no avail).
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #2 of 13 Old 04-15-2012, 08:57 PM
Shiftace
1977 CJ5
The most common cause of in neutral, clutch out noise is the throwout bearing going bad. To replace it you need to pull the tranny.
"Drivetrain vibes" while moving are usually caused by driveline u-joints going bad.
Your best bet is to check these first.
Originally Posted by gpets View Post
...it is perfectly acceptable to take a sawzall to anything you can't figure out, that is how we all learn.
Shiftace is offline
post #3 of 13 Old 04-15-2012, 08:57 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Sounds like the throw out bearing to me.
xjfever is offline
post #4 of 13 Old 04-15-2012, 09:04 PM Thread Starter
pman
Thanks guys. Shiftace, I should have mentioned that the Ujoints were the first things I changed out. I thought for sure that was the problem with the vibes. I'm still chasing down other possible culprits, but wondered if the clutch thumping could be the issue.
On the throwout bearing, I thought "pedal in" was usually where this reared it's head? It's quiet when depressed, and shifts smoothly. Looks like I'll be pulling the tranny.
pman is offline
post #5 of 13 Old 04-15-2012, 09:38 PM
Shiftace
1977 CJ5
When you push in the clutch it loads the bearing, preventing it from rattling.
Since you already changed the u-joints to no avail, you may want to jack the rear wheels off the ground, place the Jeep in gear with the motor running(rearend blocked up and in two wheel drive, of course!) and watch all the moving parts for unusual shaking or elliptical motion. Be sure to include the tires and rims in your inspection.
Also, with the motor off, shake the slip joints. They can cause the same symptoms also.
Shiftace is offline
post #6 of 13 Old 04-15-2012, 10:21 PM
Skerr
The clutch "chatter" when you start off in first? Kind of jumps and shimmies and shakes until you get going?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #7 of 13 Old 04-15-2012, 10:26 PM
Blue83CJ7
1980 CJ7
When this happened to me I though it was actually my engine bogging from being poorly tuned, but my throw out bearing was a total mess... The outer face part actually was able to move around the bearing like an orbital sander and it would vibrate like it was off-center until it centered itself
Put a new one in and I can start in second without any chatter at all.
1980 CJ7 - The Grenade
Blue83CJ7 is offline
post #8 of 13 Old 04-15-2012, 11:16 PM
only in a jeep cj
Based on the info given, my first guess would be the front bearing in the transmission. A throwout bearing shouldn't be rattling around as when the clutch is out, the face of the bearing is off the diaphragm fingers. The chatter could be a combo of a bad pilot bushing and a bad front bearing which would allow the clutch/input shaft to flop around off center.
Another good transmission test is to put the t case in neutral and run throw the gears. Gently feather the clutch out for the higher gears. A wooden stick to the ear will allow a little more of a pin point as the parts in question will be moving.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #9 of 13 Old 04-16-2012, 05:55 AM Thread Starter
pman
I had a little more "quality" reading time on the clutch last night and I keep coming to the same conclusion regarding the front bearing. I'm traveling to FL this week so I wont be able to tear into this until later, but I'll keep everyone updated.
Skerr- The noise is there ONLY at idle/in neutral/clutch pedal out. No noise when under way, shifting or when the clutch pedal is pushed "in".
Shiftace- good point on the jackstand test. I'm laughing thinking of the "hey y'all watch this" moment if it fell off the stands.
pman is offline
post #10 of 13 Old 04-16-2012, 06:35 AM
Shiftace
1977 CJ5
Be sure to have a video camera running!
As only in a jeep cj mentioned, it is quite possible that your front bearing went out and is causing all the symptoms you are describing including the driveline vibes. Bad u-joits and throwout bearings are only the most common causes.
Either way, you'll need to pull the tranny to know for sure.
Might as well surface the pressure plate and replace the clutch, pilot bearing, throwout bearing and front seal while you're there.
Shiftace is offline
post #11 of 13 Old 04-18-2012, 06:27 AM
Shiftace
1977 CJ5
I'm curious to know what you find out.
Shiftace is offline
post #12 of 13 Old 01-06-2015, 07:23 PM
LetMeoPHELIA
DId you ever solve the problem? I may have the same thing and I'm curious. Thanks.
LetMeoPHELIA is offline
post #13 of 13 Old 01-06-2015, 09:17 PM Thread Starter
pman
Never did solve it. I've driven it a good bit since that original post, and other than the noise, it shifts and drives fine. I still see the occasional post with the same symptoms, but haven't seen any resolution.
At some point I really would like to pull the engine to paint it, and I think that would be a good time to see what the culprit is. I'll update this thread when I do that.
pman is offline
In gear but won't move. Seems like clutch is broke and stuck in neutral. What to do? eaglecurt Jeep CJ Forum 8 12-01-2010 03:43 AM
How far should clutch pedal go down? Ken4444 Jeep CJ Forum 6 07-21-2010 06:12 AM
clutch pedal is too low hunter123 Jeep CJ Forum 3 07-13-2009 04:49 PM
Terrible noise when coming to a stop (clutch disengaged) Scuter83 Jeep CJ Forum 3 09-16-2007 04:39 PM
Clutch works but I hear a whirring when I press the clutch pedal to the floor? part.changer Jeep CJ Forum 12 04-10-2007 02:31 PM
