Clutch Master Cylinder - JeepForum.com
post #1 of 9 Old 06-26-2008, 01:49 PM Thread Starter
phil77
1980 CJ7
I think I need to replace my Clutch Master Cylinder. I noticed when I push the clutch in fluid is coming out where the rod from the pedal goes in. Does this sound like the fix? ANd is it hard to replace? ANy tips would be appreciated. By the way its a 82 cj 5 3 speed 6cyl.
phil77 is offline
post #2 of 9 Old 06-27-2008, 02:24 PM Thread Starter
phil77
1980 CJ7
No advice?
phil77 is offline
post #3 of 9 Old 06-27-2008, 03:34 PM
243
1978 FSJ Cherokee
Sounds like the diaphram is compromised....the clutch slave is easy to rebuild, take if off and tear it down, no directions are really required. If the bore is pitted you may need to polish it. If it's really pitted by a new/rebuild slave.
Dave's 78 Build
243 is offline
post #4 of 9 Old 06-28-2008, 09:17 AM Thread Starter
phil77
1980 CJ7
WOuld it be the slave cylinder or the clutch master cylinder?
phil77 is offline
post #5 of 9 Old 06-28-2008, 10:26 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Master cylinder leaking. Replace it and you will fix the leaking problem. Might want to do it soon, as the brake fluid will rot the paint off the bulkhead.
jeepdaddy2000 is offline
post #6 of 9 Old 06-29-2008, 09:54 AM
243
1978 FSJ Cherokee
I read the post clearly but still typed slave cylinder, JD is correct for sure. The leaking clutch master cylinder will rot the paint quick, just like the leaking brake master cylinder on my CJ.
Dave's 78 Build
243 is offline
post #7 of 9 Old 06-29-2008, 08:33 PM
armyhooker
1971 CJ5
THe new master is not that much more than the rebuild kit. Go for the new master cylinder. My was replace in about 15 mins. Easy to do.
armyhooker is offline
post #8 of 9 Old 07-07-2008, 01:16 PM Thread Starter
phil77
1980 CJ7
do i need to bleed the lines or does just pumping the clutch pedal build pressure back up?
phil77 is offline
post #9 of 9 Old 04-09-2010, 09:38 PM
1980CJ5dude
Hi Phil, I tried to send a msg to your acct but your inbox is full.
I was reading this post about your leaking clutch master cylinder and was hoping you can help me out. I've got the same problem with my '80 CJ5: the clutch master cylinder leaked all of the fluid onto the floorboard underneath my pedals.
Did you just replace the clutch master cylinder or did you also replace any other seals, etc.? How difficult was the replacement? My cylinder's got about 1/2 the fluid left in it--how did you drain the rest out of it to do the replacement?
I also read that this problem caused a lot of damage to the fuse box and fuses, but that was reading some Cherokee posts so hopefully mine wasn't affected (it doesn't appear to be).
Any advice you can pass on would sure be appreciated. I'm hoping to get this fixed over the weekend.
Thanks very much!
Erik
1980CJ5dude is offline
clutch: different bore size for master and slave cylinder kercher Jeep CJ Forum 0 10-09-2009 11:24 AM
Hyd Clutch swap, what master cylinder? BMac4x4 Jeep CJ Forum 12 08-02-2007 04:51 PM
Help, Clutch master cylinder problem my80cj5 Jeep CJ Forum 4 07-06-2006 10:17 AM
Clutch Master Cylinder Aphelion79 Jeep CJ Forum 2 06-28-2006 12:09 PM
What Clutch Master Cylinder ? Scrambler82 Jeep CJ Forum 3 03-20-2003 04:31 PM
