Clutch Master Cylinder - JeepForum.com
post #1 of 3 Old 06-27-2006, 10:54 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Hey all... I went to replace a leaky clutch master cyl. and got it all fitted in, etc. The only problem now is that my darn clutch has about 50 feet of play and just barely about 1 inch of actual clutch activity AT the firewall/floorboard... and yes I bled it like 50 times to no avail... I think the pushrod from the pedal into the cyl. is shorter than the new one? Unfortiunately I already tossed the old one so I can't swap/compare it... (Don't do mechanical work on the days the trash guys come around lol).... anyway... anyone have any ideas?
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl
T177 Tranny | Dana 300 T-Case
Dana 30 Front | AMC 20 Rear
Aphelion79 is offline
post #2 of 3 Old 06-28-2006, 06:26 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
With the master cylinder pushrod extended all the way out you should have been able to connect the clutch pedal without having to push it down hardly at all. Are you sure the little plastic tip on the slave cylinder didn't fall off when you had slack in the system?
BESRK is offline
post #3 of 3 Old 06-28-2006, 12:09 PM Thread Starter
Aphelion79
Aphelion79's Avatar
Pretty sure, ill check when im back out there tinkerin' with it...
1982 CJ7
Clutch Master Cylinder phil77 Jeep CJ Forum 8 04-09-2010 09:38 PM
clutch: different bore size for master and slave cylinder kercher Jeep CJ Forum 0 10-09-2009 11:24 AM
Hyd Clutch swap, what master cylinder? BMac4x4 Jeep CJ Forum 12 08-02-2007 04:51 PM
Help, Clutch master cylinder problem my80cj5 Jeep CJ Forum 4 07-06-2006 10:17 AM
What Clutch Master Cylinder ? Scrambler82 Jeep CJ Forum 3 03-20-2003 04:31 PM
