Clutch Master Cyl part number needed - JeepForum.com
post #1 of 3 Old 04-14-2013, 01:51 PM Thread Starter
8valve
I have searched as best I can on a 24.4K dial up.
I have a 82 CJ7, the serial number decodes to the original engine as a 2.5L.
I am doing a conversion and have bought a new clutch master and slave. I bought a NAPA NCF 72308, which their book shows for the 2.5L engine. The problem I am having is that the Clutch Master Cylinder push rod is to short. When the salve is mounted on the firewall and the clutch pedal connected, the clutch pedal is about 1/2 ways to the floor.....compared to the height of the brake pedal. The clutch master works but since it does not have full stroke, I am not getting good dis-engagement.
In measuring the Clutch Master, from the inside of the mounting flange to the absolute end of the push rod at the eye end is 4.926" I figure I need a Clutch Master with a push rod about 1 inch longer to get full pedal and have the pedal the same level as the brake pedal.
NAPA evidently sold me the wrong Clutch Master, but its the only one they show in the book. Can someone tell me the correct part number of a 82 CJ7.
Thank You
8Valve
Build Super Kill Strong, Play Hard, Drive It Home
Toy Box; http://imageevent.com/moosecreekmaple
8valve is offline
post #2 of 3 Old 04-14-2013, 06:49 PM Thread Starter
8valve
Bump
Hope someone can help. I need to get this fixed tomorrow.
8Valve
8valve is offline
post #3 of 3 Old 04-15-2013, 01:02 AM
wrongway92407
wrongway92407's Avatar
The 2.5's used a hyd clutch the 6cyl used a bell crank and linkage. There used to be a kit for a conversion but I don't remember who made it. You might with parts Mike in Ca. you didn't say what you were converting to.
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
