Clutch linkage ? after 1' BL - JeepForum.com
post #1 of 8 Old 09-18-2005, 08:34 PM Thread Starter
Hopper
So everyone knows this is my first Jeep project.I'm going to put a 1' BL on it.The CJ has a man. trans..I notice that part of the linkage is bolted to the firewall.To leave that bolted on it will angel the rest of the linkage.I like to know what I can do to lower the linkage back to being straight again.Thanks
Hopper is offline
post #2 of 8 Old 09-18-2005, 09:49 PM
fuzz401
1978 CJ7
this to the body part
the steering shaft will have to come out some to and watch your raddy fan to the shrould - and you might have to cut your floor to let the tc shift right too
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 8 Old 09-19-2005, 12:10 AM Thread Starter
Hopper
It seems the bracket bolted to the firewall needs to be lower and the arm to the clucth peddle would have to be longer.Is that what I have to do?
Hopper is offline
post #4 of 8 Old 09-19-2005, 03:36 AM
fuzz401
1978 CJ7
yes what i had to do
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #5 of 8 Old 09-20-2005, 01:31 PM
capeless
Your scaring me.
I have a Daystar 1" BL half installed and it didn't say anything about that in the instructions.
I ran out of time last night but got all the drivers side bushings in. The passenger side bolts and the front bolt under the radiator are loose just waiting for me to get home from work to finish.
What did the directions leave out that I am going to have trouble with? There is no fan shroud so that part shouldn't be a problem. What are the torque specs?
Just to add...
I broke 2 bolts, one on each side, while taking the old body bushings out. They were the bolts toward the rear, same on each side. I was fortunate enough to be able to cut the bolts flush and drill a new hole. I used a nut and washer and squeezed my fingers inside the body brace.
Man, this thing is a pain in the ***
capeless is offline
post #6 of 8 Old 09-20-2005, 08:32 PM
fromme
fromme's Avatar
You don't need to modify any part of your clutch linkage for a 1" body lift. In fact, you don't have to modify anything at all, unless you break a bolt off or spin the nut, and maybe the fan shroud. I don't know about the shroud, I use an electric fan.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #7 of 8 Old 09-20-2005, 10:31 PM Thread Starter
Hopper
I had to weld a piece of metal onto the bracket,drilled a hole about an 1" higher from the top bolt hole in the bracket and another about an 1" up from the bottom bolt hole.Using the same two bolts that come out the fire wall.Also had to add to the long clutch rod.I had to cut to the rod(3" down from where it connects to the top of the clutch peddle arm)and welded a piece in about 3/4 of an inch long.That had straighten the arm that gets pushed down and pushes in the clutch.Before I had did this mod the arm was on to much of an angel and it was binding up.I also had to cut the shifter holes back alittle.It would hit shifting to 2nd,4th gear and rev.
Hopper is offline
post #8 of 8 Old 09-21-2005, 01:05 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Originally Posted by capeless
Your scaring me. Man, this thing is a pain in the ***
Good golly, that has to be the understatement of the century! Welcome to CJ land! hahaha. Seriously, owning a CJ will own you, $$ wise, time and frustration. But it's all worth it when u go out on the trail and do better than before. Upgrades and repairs and regular maintenance are a fact of CJ life.
i have the mechanical clutch and added the heim joint replacement kit, junking most of the OEM stuff. i think it was speed shops.com or something like that-- under $60 and worth every penny. No more binding up in flexy situations and no more jamnut popping and dropping out of place when u need ur clutch the most.
I originally bought all the hydro conversion kit from 4wd.com, but after adding the navajo brake booster from harold off, the clutch master cyl will not fit. so if anyone cares, i'll unload the entire NIB kit for cheap!
anyway, look into the heim joint replacement kit-- u'll be glad u did now, not later when the clutch rod finally wears thru (and it will over time) and ur SOL out on the trail.
pix upon request.
mb
Edit: here is one option:
http://www.tellico4x4.com/catalog/pr...ducts_id/15846
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
Clutch Linkage RH31379 Jeep CJ Forum 4 04-07-2008 02:25 PM
Clutch Linkage AMC Power Jeep CJ Forum 9 01-01-2007 11:38 AM
New Clutch linkage rod cyclic17 Jeep CJ Forum 1 09-13-2005 05:08 PM
Hyd Clutch linkage JerDog53 Jeep CJ Forum 5 02-07-2004 08:16 AM
Clutch linkage West Jeep CJ Forum 7 08-05-2002 05:47 AM
