Clutch Linkage - JeepForum.com
post #1 of 5 Old 04-07-2008, 12:24 PM Thread Starter
RH31379
1983 CJ7
Clutch Linkage
I have an AJ's fiberglass body on my 83 cj. the clutch seems to catch extremely high and i am out of room for adjustment. Has anyone every had a similar problem? I was thinking that maybe the linkage has to be lengthed somehow to compensate for the thicker firewall, i know the break booster had to be extended to reach the pedal, so I was thinking maybe the linkage between the fork ans dell house might to?
besides the 83 cj-7, also have an 87 yj, 6cyl., 5spd, weber upgrade, 6.5' western uni mount plow, also a 2000 Sahara, 4.0, 5 spd
RH31379 is offline
post #2 of 5 Old 04-07-2008, 12:35 PM
Mike Romain
Umm, mine adjusts the other way I think. It is supposed to have about 3/4" of slop at the top, then it grabs. If the clutch engages high with the slack at the top, it is worn out usually.
To get the slack up top, I loosen my linkage, not extend it.
The set of the body tub does affect the linkage also. When I knock my tub off it's mounts a bit, I notice it in the clutch pedal. The frame mount should be flush with the firewall.
Mike
Mike Romain is offline
post #3 of 5 Old 04-07-2008, 02:08 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Is your linkage worn out? Mine had slots for holes from were the linkage wore out.
I also had flipped my linkage mount and put it on the frame instead of the fiberglass tub.
Eventually i went with an agjustable linkage with Hime joints.
John Strenk is offline
post #4 of 5 Old 04-07-2008, 02:11 PM
John Strenk
1976 CJ5
Eventually i went with an adjustable linkage with Hime joints.
post #5 of 5 Old 04-07-2008, 02:25 PM Thread Starter
RH31379
1983 CJ7
Linkage is new, been in there less then 3000 miles since my rebuild. it's the quadratec kit.
RH31379 is offline
Clutch Linkage AMC Power Jeep CJ Forum 9 01-01-2007 11:38 AM
Clutch linkage ? after 1' BL Hopper Jeep CJ Forum 7 09-21-2005 01:05 AM
New Clutch linkage rod cyclic17 Jeep CJ Forum 1 09-13-2005 05:08 PM
Hyd Clutch linkage JerDog53 Jeep CJ Forum 5 02-07-2004 08:16 AM
Clutch linkage West Jeep CJ Forum 7 08-05-2002 05:47 AM
