Clutch Linkage - JeepForum.com
post #1 of 10 Old 12-30-2006, 06:48 PM Thread Starter
AMC Power
Clutch Linkage
I am converting from the AMC 150 to the 258 and I have the hydraulic clutch. Will that still work with the 258 or do I have to buy all new linkage. I am really confused on how it all works. The four cylinder's clutch fork was enclosed inside the bellhousing and the slave cylinder pushed it when the clutch pedal was depressed. There was no other linkage. I have a feeling that this is going to change with the 258 because the clutch fork sticks out of the bellhousing and a mechanical linkage will depress it. What does the hydraulic master cylinder do then?? Is it still needed? Help me please!
AMC Power is offline
post #2 of 10 Old 12-30-2006, 09:36 PM
molsenice
1964 CJ5
just a thought as I am no expert here and I can only visualize the situation - what if you were to fabricate a mounting plate for the slave to push the fork - as long as it is in the right location - it will push. I hope ya have the ability to cut and weld at least angle iron or this could be tough - might be an after market plat just for this purpose
molsenice is offline
post #3 of 10 Old 12-30-2006, 10:22 PM
SQF1
1976 CJ5
From what I can see from online searching... All you need to do is swap out the 150 slave to the 258 style slave and replace your hydraulic line with a later version. The master will be the same.
Here is the 150 style slave
And here is the 258 style (also what I have on my 304 w/T150)
I bought both slaves and hydraulic lines for my setup as fabbing it all myself I didn't know which would be better. I ended up using the style you need and having the style you already have sitting on the bench still, otherwise I would just give em to you.
SQF1 is offline
post #4 of 10 Old 12-31-2006, 07:19 AM Thread Starter
AMC Power
I bought a new hydraulic line, but I still need to purchase the new slave cylinder for the 258. Where does the slave cylinder bolt onto the bellhousing at?
post #5 of 10 Old 12-31-2006, 08:15 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Mine bolts right to the bellhousing "lip" in-line with the clutch fork. If you were looking at it from dead front, it would be at about the 4 o'clock position. No drilling or anything.
BESRK is offline
post #6 of 10 Old 12-31-2006, 05:06 PM
gosupes
Somthing like that. And SQF1 was correct, just a new line and slave, use your old master.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #7 of 10 Old 12-31-2006, 06:46 PM
SQF1
1976 CJ5
What bell housing is that for? Just curious
SQF1 is offline
post #8 of 10 Old 01-01-2007, 09:07 AM Thread Starter
AMC Power
Thanks! I like the clear picture.
post #9 of 10 Old 01-01-2007, 09:21 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I ditched that plastic tip at the end of the clutch rod too.. made a longer rod instead. I had that tip split open on me in traffic one time. Was sitting there in first gear and all of a sudden, the Jeep started moving forward. Almost hit the car in front of me. I killed it by stepping on the brakes and lugging the engine. Once I figured out what was wrong, I had to drive home with no clutch pedal.
BESRK is offline
post #10 of 10 Old 01-01-2007, 10:38 AM
gosupes
Yeah, I did the same thing. I had just enough engagement to get home, just a little rough getting into first. Been good ever since.
That was a T5 but it looks similar on most any bell housing.
gosupes is offline
Clutch Linkage RH31379 Jeep CJ Forum 4 04-07-2008 01:25 PM
Clutch linkage ? after 1' BL Hopper Jeep CJ Forum 7 09-21-2005 12:05 AM
New Clutch linkage rod cyclic17 Jeep CJ Forum 1 09-13-2005 04:08 PM
Hyd Clutch linkage JerDog53 Jeep CJ Forum 5 02-07-2004 07:16 AM
Clutch linkage West Jeep CJ Forum 7 08-05-2002 04:47 AM
