Does anyone out there have any links to a custom clutch linkage. I already have a heim where the throwout rod meets the bellcrank, I am planning on puttin one at the other end too. I need a new pedal to bellcrank rod. Also I keep breaking the ball joints at the body. Does anyone have any alternate setups to get rid of this ball joint. I have thought of making a new bell crank with a rod running through it using bearings, I have also thought about trying to use a heim out of the firewall to go around a fitting welded onto the bellcrank I already have. Thanks for any help.
