-   -   clutch linkage (http://www.jeepforum.com/forum/f8/clutch-linkage-19898/)
manhattanjeep 09-30-2002 08:01 PM
clutch linkage
Does anyone out there have any links to a custom clutch linkage. I already have a heim where the throwout rod meets the bellcrank, I am planning on puttin one at the other end too. I need a new pedal to bellcrank rod. Also I keep breaking the ball joints at the body. Does anyone have any alternate setups to get rid of this ball joint. I have thought of making a new bell crank with a rod running through it using bearings, I have also thought about trying to use a heim out of the firewall to go around a fitting welded onto the bellcrank I already have. Thanks for any help.
werewolf7111 10-04-2002 09:38 PM
I experimented with several methods and heres what i found works best
for the bellcrank- fab you one with 1/2" water hardened drill rod for the center( thru shaft)and make a sleeve that fits over it ( any machine shop will bore you one for almost nothing)
for the rods- use B-7 threaded rod for the adjuster and drill rod for the pedal
hope it helps
joe MSME, PE.
The time now is 10:54 AM.
