Clutch linkage - JeepForum.com
post #1 of 8 Old 08-03-2002, 04:34 PM Thread Starter
West
Clutch linkage
When I installed a wrangler tub on my CJ frame I used 1 inch lift body mounts. I'm almost to the part where I reinstall the clutch linkage. (It's the rods and bellcrank style) Am I going to run into any problems caused by the 1 inch of body lift?
West is offline
post #2 of 8 Old 08-03-2002, 05:00 PM
only in a jeep cj
YES, one side pivots on the bracket at the bellbousing. The other side pivots on a bracket attached to the body (now 1 inch higher) so you can try to lower this body bracket, but then the rod going through the firewall will be too short. You can cut it and weld in a section to make up the difference. OR do the switch to a hydraulic set up. Not the internal throwout bearing kind that leak all inthe clutch, but the one used on many YJ's and 4 cyl CJ's.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 8 Old 08-03-2002, 05:23 PM Thread Starter
West
Switching to the hydraulic was my first idea. Because I went over it all in my head and came up with the same hurdles you did. When I tried to bolt the master to the firewall the brake booster was in the way. I should have stuck with manual brakes.
West is offline
post #4 of 8 Old 08-04-2002, 08:51 AM
only in a jeep cj
west,
Did you use a different brake booster than stock, or a different clutch master than stock, because there should be room for them to fit side by side.
Ed
1975 CJ-6 1983 CJ-8
post #5 of 8 Old 08-04-2002, 08:56 AM
only in a jeep cj
west,
Ed
1975 CJ-6 1983 CJ-8
post #6 of 8 Old 08-04-2002, 09:20 AM Thread Starter
West
I used the booster for my CJ application but with power brakes. I odered the clutch master for the early 80s CJ with 4 cylinder. Do you have the hydraulic? I'd love to see pics of how it's done. I know that the wrangler uses a clutch master cyl. with the resovoir mounted separately.
West is offline
post #7 of 8 Old 08-04-2002, 11:05 PM
only in a jeep cj
I'm about to do the hydraulic swap myself. I have all the parts, just waiting till my worn clutch goes so I can do all of it at once. I was lucky. I stumbled across a 4 cyl CJ-8 in a junkyard and got the whole set up (minus the small heatsheild on the slave). I even got the correct swing pedal so I don't have to cut/weld/and fab my old one. I'm running stock power brakes and my firewall has the indent / pre cut out of where the clutch master goes. Although I haven't made the hole yet, there is room when I put the part in place and check for clearance. My brake booster is set off the firewall some 5 to 6 inches with the swing arm bracket. The clutch master goes beside that. I believe it's the same type of set up used in the YJ (your tub should be the same) The master I got out a the junk o yard looks to be the same as the ones sold in the 4x4 catalogs. ( the yj uses 3 different kinds: 87 to 90, 91 to 93 and 94 to95 while the CJ uses the same part for all 4 and 6 cyl. models. *One more for the AMC vs Chrysler debate)
Ed
1975 CJ-6 1983 CJ-8
post #8 of 8 Old 08-05-2002, 04:47 AM Thread Starter
West
Does ANYONE have a pic of a CJ with power brake booster and clutch master side by side?
West is offline
Clutch Linkage RH31379 Jeep CJ Forum 4 04-07-2008 01:25 PM
Clutch Linkage AMC Power Jeep CJ Forum 9 01-01-2007 10:38 AM
Clutch linkage ? after 1' BL Hopper Jeep CJ Forum 7 09-21-2005 12:05 AM
New Clutch linkage rod cyclic17 Jeep CJ Forum 1 09-13-2005 04:08 PM
Hyd Clutch linkage JerDog53 Jeep CJ Forum 5 02-07-2004 07:16 AM
