clutch kit choice - JeepForum.com
post #1 of 15 Old 04-15-2014, 11:01 PM Thread Starter
cookingguy
1979 FSJ Cherokee
clutch kit choice
So I am in the market for a clutch kit for my cj. I am going to be running a 360 4:56 gears and a t177 trans. I have looked at both center force and clutch masters. My question is are either of these a good choice for a trail and rock crawler rig? what are the advantages over something less costly
cookingguy is offline
post #2 of 15 Old 04-16-2014, 03:52 AM
RedNeckCorvette
1979 CJ7
I would recommend Luk clutches. They are what the new car industry uses mostly. Since I started using them I have had a nice easy peddle and never a slipping problem. In fact I put some time in the Oregon coastal sand dunes and that is about the greatest load you can put on a clutch.
I also have one in my five yard dump truck 1964 f750 air brakes an old forest service rig with ten lug wheels hauling up to 26,000. I get it on some steep long grades in low gear the luk clutch does not slip. The one prior did and once removed it looked like new.
Red Neck
RedNeckCorvette is offline
post #3 of 15 Old 04-16-2014, 05:23 AM
Mike Romain
You want to have a real strong left leg if you go centerforce. It makes for a very heavy pedal that is no fun in traffic.
Mike
Mike Romain is offline
post #4 of 15 Old 04-16-2014, 05:41 AM
78FordF150
1983 CJ7
The Luk clutch kits in my opinion are a good choice if your not going to do a lot of full throttle assaults on asphalt doing burnouts or pulling people out of the mud where you are really lugging the motor in a high traction situation.
I have run CenterForce clutches in the past in a CJ5 with a 400hp 360 and I could not tell a difference in the clutch peddle feel.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #5 of 15 Old 04-16-2014, 06:21 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Another vote for Luk clutches here. I get mine at NAPA.
Matt
Matt1981CJ7 is online now
post #6 of 15 Old 04-16-2014, 06:24 AM
kirbot
1981 CJ7
I have an AMS kit from quadratec. It was cheap and it's working just fine.
I probably have about 10k on it so far.
1981 CJ7, AMC 258, MC2100, T18, Dana 300, OME 2.5" lift, front locker, 32" Kenda mud terrains
kirbot is offline
post #7 of 15 Old 04-16-2014, 11:35 AM
roadhog304
1973 CJ5
I am using a LUK clutch also. I would not swear to it but if I hammer it hard on black top in 2nd ( 360 and T18) gear it sometimes feels like it slips a bit but it could be my imagination. Other than that I have not had a bit of trouble out of it.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
post #8 of 15 Old 04-16-2014, 12:29 PM Thread Starter
cookingguy
1979 FSJ Cherokee
Well it sounds like the LUK is a good choice. I am just looking for something that will do great on rocks since this jeep is not my dd its going to be more for the trails
post #9 of 15 Old 04-16-2014, 12:59 PM
RedNeckCorvette
1979 CJ7
You will never look back.
RN
post #10 of 15 Old 04-16-2014, 01:29 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Matt
x3
Just make sure you break it in correctly. According to their directions, once adjusted, Do at least 3, 20' burnouts.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #11 of 15 Old 04-16-2014, 01:54 PM Thread Starter
cookingguy
1979 FSJ Cherokee
Originally Posted by hutch1200 View Post
x3
Really I get to do burnouts. I don't know if that's a good idea with a brand new built 360
post #12 of 15 Old 04-16-2014, 04:03 PM
RedNeckCorvette
1979 CJ7
I left Toooo many rear ends behind doing just that.
Red Neck
post #13 of 15 Old 04-16-2014, 06:20 PM
hutch1200
hutch1200's Avatar
1979 CJ7
Break the engine in the way you plan on driving it. Like ya stole it!
RedNeckCorvette- Time to find the weak links is now!
post #14 of 15 Old 04-16-2014, 06:27 PM
CJJohn01
1979 CJ7
Yup, it will either go or blow!! lol
Sent from my C811 4G using JeepForum
CJJohn01 is offline
post #15 of 15 Old 04-16-2014, 11:19 PM
RedNeckCorvette
1979 CJ7
I did that racing, new engine off the bench after running a half hour or so in the machine off to the track. Time had a lot to do with that. Sunday was race day and I had to be on that track. I never brake in my engines like that any longer, I take the time and brake them in like I am honing something.
You can learn a lot from failure.
RN
