clutch installation - JeepForum.com
post #1 of 3 Old 07-17-2003, 05:49 PM Thread Starter
tera1298
clutch installation
How do I know if I put the clutch disc on properly. There is a flat side and a side that sticks out,I put the part that sticks out on the fly wheel side ,becaue it fit better and the clutch disc cover would have of hit the springs when the clutch is engaged,their seemed not to be to much room between the springs and the clutch plate,please tell me that i did not install this wrong, the clutch is very tight, any other ideas why the clutch would be very firm
tera1298 is offline
post #2 of 3 Old 07-17-2003, 06:46 PM
mxg342
mxg342's Avatar
Its been years since I've dove into a clutch job on a CJ but I can tell you that the spring pack (the side that sticks out) of the clutch disc usually faces the pressure plate. Did the disc say anything about flywheel side. The usually stamp that somewhere on the clutch disc.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #3 of 3 Old 07-18-2003, 11:53 AM
CSP
The clutch disc is usually stamped "front" or "flywheel" somewhere on the center ring.
CSP is offline
Help with Clutch Installation on a 1972 CJ ASteve Jeep CJ Forum 8 12-11-2009 06:15 AM
Heim Joint Clutch Linkage Installation Problems? Uncle Russ Jeep CJ Forum 4 02-24-2008 04:40 PM
Clutch Installation on AMC 258 AMC Power Jeep CJ Forum 10 12-30-2006 09:10 AM
Rookie clutch disk installation question hfjeff Jeep CJ Forum 2 06-10-2005 07:39 PM
Clutch Belcrank linkage installation CJ5_Tom Jeep CJ Forum 4 03-02-2003 07:11 AM
